Old 09-09-2010, 02:01 PM
BobA BobA is offline
Default Greenline 7 speed - Steel or Alum?
I really like the looks of the Greenline 7 speed cruisers....
They have one in steel frame and one in aluminum frame with some better components..
Both use the same forks (steel)......aluminum is about 9-10 lbs. lighter....
I've read that there are differing opinions as to whether to use aluminum or steel frames....
Thoughts??? Should I save the weight? or go fo steel due to possible strength concerns with aluminum?? (6061-T6)
I plan on doing a bit of peddaling so was thionking any weight saved is a good thing!!!
Thanks from a newbie....
Old 09-09-2010, 02:09 PM
Nougat Nougat is offline
Default Re: Greenline 7 speed - Steel or Alum?
Steel. The weight difference is negligible. Lose a few pounds yourself, and it's a wash.
When asking for advice, you did not specify whether you wanted only good advice.
Get on the member map
