Old 07-22-2008, 12:05 PM
FileStyle's Avatar
Default throttle control
I purchased a boy go fast motor kit and happy with what I saw , however the twist throttle had this little brass piece inside the cap where you hook up your cable . my first kit did not have this and I tried to pull this piece out to mount the darn thing , but it would not come out. so I ended up using a brake lever instad of the twist throttle (its what I currently using on my first ride) it almost seems to me they want you to drill a small hole in your handlebar to mount it! has anyone else run into this problem?
FileStyleCycles
Old 07-22-2008, 12:36 PM
Spunout's Avatar
Spunout Spunout is offline
MB Builder Extraordinaire
Default Re: throttle control
i'm not familiar with that brand of kit. some people will say file that piece down. i have had some with not brass, but a plastic nub. i drilled a hole in the bars, put the nub in, and a week later the nub broke off. almost ate sh!t in middle of the street.
now, when i see that kind, i grind the nub off completely, and drill a hole thhr throttle clamp and bars...throw in a set-screw. will never move.
Old 07-22-2008, 04:12 PM
mike373 mike373 is offline
I heated the brass nub up with a lighter, and pulled it right out with pliers while the plastic was still hot. Piece'o cake.
Mike
Old 07-22-2008, 06:21 PM
RedB66's Avatar
RedB66 RedB66 is offline
I have found that those little pins break off also. What I do is wrap a six inch piece of tape around the bar where the throttle tightens down. Seems to work for me...it keeps the handle from spinning.
MOTORBICYCLING.COM STICKERS
Old 07-22-2008, 07:05 PM
Urbex Urbex is offline
I use my brake lever for the throttle, in my opinion it beats the twist hands down.
To each his own.
Old 07-25-2008, 09:33 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Grab it with some pliers & pull it out! Never had a problem!
