Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Welcome Forum > Welcome to the World of Motorized Bicycles
Welcome to the World of Motorized Bicycles Forum announcements and instructions for posting on motorbicycling.com. To start a new thread choose the appropriate area. No new threads can be started in this area
Old 02-15-2012, 03:14 PM
Derks420's Avatar
Derks420 Derks420 is offline
Default Re: Motorbicycling.com Member Map
Trial and error brother! Gota start somewhere!!!! Good Luck!!
Old 03-28-2012, 06:56 AM
Dave31's Avatar
Dave31 Dave31 is offline
Smile Re: Motorbicycling.com Member Map
Bump....
Check out our member map and add yourself if you like
http://zeemaps.com/map?group=178631
No need to add your real address; zip code, nearest intersection, city ect. will work just fine.
Old 03-30-2012, 12:33 AM
happycheapskate's Avatar
Put a photo of your bike in your member user page, and people will be glad to share products and information with you. I've been on this page quite a while now, and I think I would have just thrown my 1st motor away and saved up for a standard moped, if I hadn't gotten so much info here.
Originally Posted by Lons1980 View Post
I just joined but, so far this looks like a pretty cool way to learn more about bike engines. I've had a stretch limo cruiser with a "tank" for awhile but I can't figure out how to fit an engine on there. The bottom rail is thick squared off and I can't fit a gas tank on the top bar (aka tank). Doesn't help that I don't know a lot about engines...lol I'm on the map so maybe someone could help me out here.
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 04-17-2012, 02:46 AM
1flyingfool's Avatar
1flyingfool 1flyingfool is offline
I'm There too,and it looks like I'm REAL lonley out in Washington
Old 07-02-2012, 02:16 AM
MysterySandwich's Avatar
MysterySandwich MysterySandwich is offline
Added my self!
I don't actually have a motor-bicycle yet, but i will soon...
The best part about asking questions, is that you add to the pool of information that future builders can look back on through the search function
Old 07-02-2012, 03:40 PM
A Future Pilot A Future Pilot is offline
I added myself! Anyone else in the Jackson, TN area? (I don't see anyone on the map...not within comfortable motorized bicycle riding distance that is...)
My first build is gonna be built within a couple weeks...waiting on parts to ship lol
Old 07-02-2012, 04:12 PM
Dan's Avatar
Dan Dan is offline
Staff
I am sure I have seen other members from Jackson TN Pilot. The link below is a how to find folks in your area posted by Paul.
http://motorbicycling.com/showthread.php?t=17792
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 07-18-2012, 10:51 PM
mandomadness mandomadness is offline
im in desperate need of a mechanic. so i changed out my old chain tensioner for a new spring loaded tensioner that turned out to be crap. now i cant re install my old chain tensioner with the proper amount of tension. i em seeking a motorized bike mechanic to properly re install it for me asap, i will pay $. im in the Denver area, pleas help
Old 07-19-2012, 10:46 AM
KCvale KCvale is offline
If you are having that many chain issues it is NOT the tensioner.
Tensioners will NOT correct a poor sprocket mount or any other issue.
In my years I have seen dozens of other peoples builds and 80% of any chain issues are because of that rear sprocket as that is the hardest thing to get right.
10% is because of a bend rim or shot hub bearings (very common on Huffy type cheap bikes), 5% because of a bad chain, and the last 5% is motor sprocket related issues or a poor motor mount.
In short don't try to work around a problem with a band aid, find and and fix the root cause.
Quick checks:
From the side of your bike hold the frame with one hand and push your back wheel side to side, does it move? Then it's your hub.
Then in the same position hold the frame and grab your motor and try to push it side to side, I don't mean nudge it either, I mean shove it hard, does it move? Then it's your motor mount.
All good? then look at the alignment from the sprocket to the motor, do they line up? if not the sprocket is too far in or out.
Is that good too? Then spin the wheel and look at the side of the sprocket, does it have side to side or up and down wobble (chain gets tight then loose)? The sprocket isn't mounted right.
I have big lungs so I can scream this a lot before I get blue in the face...
TENSIONERS DO NOT FIX MECHANICAL PROBLEMS!
KC's Krusiers Builds
Old 07-19-2012, 03:28 PM
@KCvale, thanks dude. ill check all those.
MotorBicycling.com
