Old 07-21-2008, 06:25 PM
Can Harm Hen's Avatar
Can Harm Hen Can Harm Hen is offline
Default What can you use to make an intake gasket?
On my way home from class, I noticed that the engine was idling higher than usual. By the time I got home, it was smoking a bit. I immediately shut it down, and I discovered that there is a hole in the intake gasket spraying gasoline all over the cooling fins!
Does anyone have a suggestion on how and what to replace the gasket with? I've heard cereal boxes make acceptable gaskets.
-Herman
"Do not take life too seriously. You will never get out of it alive." -Elbert Hubbard
Old 07-21-2008, 06:27 PM
stude13 stude13 is offline
Default Re: What can you use to make an intake gasket?
a manila envelope works
Old 07-21-2008, 06:35 PM
Dave31's Avatar
Dave31 Dave31 is offline
Go to your local auto parts store and pick up a roll of gasket maker...it's only a few bucks and way better then any cereal box.
Old 07-21-2008, 07:49 PM
Bikeguy Joe's Avatar
Cereal box gaskets are for the birds....and leak.
Old 07-27-2008, 08:16 AM
shiloh0 shiloh0 is offline
i used a scrap piece from the edge of a 350 chevy engine gasket set. i have a bunch of hotrod stuff horded around. it worked fine, better than the one supplied cause it doesn't soak up as much gas mix as the china one. it was made from the same stuff fairraicing21 suggested above.
Old 07-27-2008, 08:31 AM
Pablo's Avatar
Pablo Pablo is offline
REAL Gasket material is inexpensive. Cut it out. Smear with Blue RTV gasket stuff, put it together quick. Done.
Old 08-08-2010, 08:21 PM
severedcorps severedcorps is offline
sorry to resurface this thread but i have a question
is blue rtv gasket stuff the same as rtv silicone sealant (the stuff u use to seal cdi wires and magneto from rain/water) because i would like to save some money and only have to buy one thing... i am limited in my funds, so im trying to spend as little i can
Old 08-08-2010, 09:10 PM
2door's Avatar
2door 2door is offline
Any good gasket sealer will do the job. Permatex makes several different types. Just tell the parts counter guy what you're doing and he'll guide you to the right product. I agree with Joe too. Gaskets should be made from gasket material...not cereal boxes or envelopes. Do it right the first time and you won't have to do it again.
Old 08-09-2010, 02:57 AM
BarelyAWake's Avatar
BarelyAWake BarelyAWake is online now
Jus' to be different...
Pressed for time and w/o any gasket material left, I made my last intake gasket out of the back of a leather work glove - don't laugh, leather used to be used for gaskets quite frequently...
pre 1930's that is lol
Old 08-11-2010, 08:15 PM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
I'm with these guys. Gasket material is cheap enough and MADE for this job. Please eat the Wheaties yourself, they're not so good for your bike.
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
