Old 08-28-2010, 09:29 PM
silverbear's Avatar
silverbear silverbear is offline
The Boy Who Never Grew Up
Default Could use help installing a pull start kit on HT bicycle engine
I could use some pointers here on installing a pull start on PK-80 engine which did not come with one. I bolted things together and discovered the business part of the pull start assembly rubs against the magneto bolts under it. I looked in my hardware stores to see if I could find bolts with a lower profile, but didn't. So, what's the fix? There's just so much real estate on the central bolt holding the assembly in place so putting a spacer in there doesn't seem possible. Who has made this work? Do you grind away some of the bottom of the pull start assembly where it contacts the bolt heads? I don't want to wreck anything and also really want for this to work. Any advice is much appreciated.
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
Old 08-28-2010, 09:45 PM
Goat Herder's Avatar
Gutter Rider
Default Re: Could use help installing a pull start kit on HT motor
I am not that familiar with the pull start Silverbear . Wish I could help got any picts?
Old 08-28-2010, 10:01 PM
silverbear's Avatar
I'll see if I can get some photos tomorrow.
SB
Old 08-28-2010, 10:02 PM
Derks420's Avatar
Derks420 Derks420 is offline
check out my post. differnet engine, but same problem
http://motorbicycling.com/f15/pullst...ion-21466.html
Old 08-28-2010, 10:16 PM
silverbear's Avatar
Derks420,
You da man! So first I'll remove the washers from the magneto bolts and replace them with blue lock tight, the shave down the bell with grinding until it clears. Yes, it would be nice if they fit in the first place. Will let you know how it goes.
SB
Old 08-28-2010, 10:19 PM
Derks420's Avatar
Awsome!! Yea, you should remove the washers, I did. Should work fine, good luck!
MotorBicycling.com
