Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 07-19-2008, 04:12 PM
Motoschwinn's Avatar
Default New plug and wire am I OK? Kings 70cc 3100miles.
Ok, my old wire and boot were looking pretty bad. They are on their 4th year. I got a accel universal 8mm HiTemp Super Stock plug wire with boot and a new NGK B6HS plug... Fired right off, (MUCH quicker than normal) and I just did a quick run. anyone know of any foreseeable problems with this combo? Will it affect the CDI?
Thanks!
Old 07-19-2008, 04:22 PM
Dave31's Avatar
Dave31 Dave31 is online now
Default Re: New plug and wire am I OK? Kings 70cc 3100miles.
You should be just fine
Old 07-19-2008, 05:38 PM
Tj Bunch Tj Bunch is offline
I tried an 8mm and could not make it fit the coil so just pulled an old 7 off the shelf and it fit's.
Old 07-19-2008, 05:45 PM
Dave31's Avatar
You could trim just enough of the insulator off so it fit's inside the CDI
Old 07-19-2008, 07:41 PM
That is what I did. I just trimmed it down, and on top of that I exposed about 1/2" of the core just to make sure there was good contact. Maybe in a month or so, I'll seal it up with silicone to make it water tight.
Old 07-19-2008, 08:36 PM
Thanks Guys, I had not even thought of trimming it down i was afraid of voltage leaks.
Old 07-20-2008, 03:30 PM
jf30cp's Avatar
jf30cp jf30cp is offline
did you find that wire sold by itself or did you have to buy a set? is it a copper core wire?
Big Boss Hoss
My "happy time" engine is so damn happy I heard it giggle at me today
Old 07-20-2008, 03:37 PM
It was a universal replacement deal. Came with a few different boots, connectors and lube. Plus about 6' of 8mm wire. No it wasn't a copper core. The kit ran me $9.00. Bike seems to fire up much quicker with the new wire, and spark plug boot along with the new NGK plug.
Old 07-20-2008, 08:25 PM
Bikeguy Joe's Avatar
Copper core is not needed as you know.
Old 07-21-2008, 10:53 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I've always been a little worried about using that fiber core wire, that it might get a little messed up trying to screw it into the boot & CDI...?
