Old 07-18-2008, 08:50 AM
boylove35 boylove35 is offline
Default motor smoking
I ran my bike yesterday for about 5 minutes, when I turned the motor off is started smoking like if it had overheated. Is this normal?
Old 07-18-2008, 09:56 AM
jasonh's Avatar
jasonh jasonh is offline
Default Re: motor smoking
No, it's not normal.
Check your spark plug for a thick oily residue. What ratio oil mix are you running?
Old 07-18-2008, 10:21 AM
I'm mixing 20:1. I'm still breaking in the motor. I just have ridden it 3 times with yesteray.
Old 07-18-2008, 10:42 AM
Ilikeabikea's Avatar
Is the smoke coming out of the exhaust?
Old 07-18-2008, 10:55 AM
I think so. It was dark, I just saw it smoking, and I noticed the exaust.
Old 07-18-2008, 11:18 AM
If your running 20:1 it's probably just oil burning in the muffler. I wouldn't worry about. Like Norman says "Ride it like ya stole it".....................
Old 07-18-2008, 11:27 AM
Thanks, I'll keep an eye on it. If it keeps it up, should I pour more gas in the tank to make it leaner?
Old 07-18-2008, 11:49 AM
After the manufacturers suggested breakin period I would run 32:1. Smoke coming out of the exhaust won't hurt anything........................
Old 07-18-2008, 11:57 AM
jasonh's Avatar
It'll just make a mess is all
Anyway, after you are finished with the break-in period, if it still smokes, give everything a good cleaning. If it STILL smokes, then there may be more questions to answer.
Old 07-18-2008, 02:54 PM
Bikeguy Joe's Avatar
Don't just pour gas into the tank to lean out the mixture....danger danger Will Robinson!
