Old 07-17-2008, 07:42 PM
jf30cp's Avatar
jf30cp jf30cp is offline
Wink need the plastic wheel for idler
my idler roller stripped out. does anyone have one laying around and would want to sell it? the plastic roller is all i need.
jeff
Big Boss Hoss
My "happy time" engine is so damn happy I heard it giggle at me today
Old 07-17-2008, 08:04 PM
jf30cp's Avatar
Default Re: need the plastic wheel for idler
also i need the stud that goes thru it sorry. jeff
Big Boss Hoss
Old 07-17-2008, 08:10 PM
stude13 stude13 is offline
head for the hardware store
Old 07-17-2008, 11:17 PM
cdoug50 cdoug50 is offline
Looks like thatsdax.com has it in stock..ball bearing with the mounting stud for 11.99 plus shipping. You might be better off to buy two and get free shipping. I'm pretty sure u could sell the extra one with no problem.
Page Title
Old 07-18-2008, 06:43 AM
Bikeguy Joe's Avatar
...or try to make one from some hardware and a skateboard wheel.
Old 07-18-2008, 11:48 AM
FileStyle's Avatar
someone near you or someone you know has a old skateboard laying around or visit your local roller rink for a old wheel. put a stud through the wheel and chuck it in a drill press and use a old screwdriver to lathe the center of the wheel ( to make a channel about 3/8"-1/2" deep.
FileStyleCycles
Old 07-18-2008, 01:52 PM
You don't even need a channel in it, just the roller will work fine.
Old 07-18-2008, 02:02 PM
FileStyle's Avatar
the skateboard wheel needs a channel or the chain will fall off , it is also a guide for the rear sprocket ; to keep the chain from climbing the rear sprocket!
FileStyleCycles
Old 07-18-2008, 02:05 PM
If the skateboard wheel is lined up with a straight chain run, no groove is needed as the tensioner only acts as a tensioner, not a chain guide.
Old 07-18-2008, 02:06 PM
P.S., I usually run my chains on the loose side and never had a problem with the chain climbing the sprocket.
