Old 07-15-2010, 05:35 AM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
Default Re: Some ?s
make sure your exhaust pipe flange is straight and uh, whaddayacalit, y'know, not bent.
sometimes they don't mate up flush with the port, and the gasket doesn't have enough "give" to make up for it.
usually, you can sand it down using a flat surface to take out any imperfections.
as far as the tank goes, those bolts suck. if you tighten them down to much, you crack the welds. sometimes, even if you don't tighten them down to much they'll leak.
if you drain the tank, then use a wire wheel or sandpaper or whatever and grind off all the paint around the studs, make sure it's clean, free of all gas and oil. JB weld works pretty good.
there's a product called "seal-all" that ace hardware has that'll work temporsrily, too. it's like a glue that can go on over gas.
Old 07-19-2010, 07:26 PM
xzackx xzackx is offline
Default Re: Some ?s
yea i got some im gonna try and already ordered a new exhaust pipe got a barrys thunderpipe from ebay hope it sounds nice and works and got some gasket material to cut and fit hope it all works out and btw yea i blew the exhuast gasket
