Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Motorized Bicycle Trouble Shooting
Motorized Bicycle Trouble Shooting Use this area to post problems that may arise, if you could use some help in figuring out what is wrong with your engine and what needs to be done to achieve top performance.
Old 06-23-2010, 06:51 PM
BADBOOH's Avatar
BADBOOH BADBOOH is offline
Default Manic Mechanic motor mount?
Any thoughts on the manic mechanic motor mount? I keep snapping my seat tube shafts in the motor block, this is becoming a problem, so I am wondering first if the manic mechanic motor mount will help, second does the mount raise the motor, therefore reduce space for the engine to clear the secondary top tube, and lastly where can I order one since Manic does not take any more retail orders. Any other info reguarding motor mount issues welcome. Thanks!
Old 06-23-2010, 07:14 PM
Mac's Avatar
Mac Mac is offline
Default Re: Manic Mechanic motor mount?
Looks like you are running an extended front mount. I had the same problem on one of my cruisers, seems like to offset torsional loading (shear actually) the motor needs the cradling of the down tube, I kept breaking studs over and over, I guess Jims mount should help, I changed bikes that the motor would fit in better. I see some fine builds with all sort's of mount extentions and wonder HOW does that hold... Maybe I ride too hard, am too fat, go up hills that are too big... I know my motor just makes too much HP!!LOL Man a top mount head would be nice, but would probably open a can of resonance worms. Hope that helped.
Mac
Old 06-23-2010, 10:22 PM
Venice Motor Bikes's Avatar
If you keep breaking the rear engine studs, you're probably over torquing the bolts & the front probably isn't solidly mounted either.
& don't hold your breath for Jim (Manic Mechanic) to produce those mounts...
Follow VMB on facebook>>> facebook.com/VeniceMotorBikes
Follow VMB on Instagram>>> instagram.com/venicemotorbikes
Old 06-24-2010, 12:30 AM
corgi1's Avatar
corgi1 corgi1 is offline
has anyone used several door hinges with bolts where the hinge pins go (to lock them in position)and u bolts to the frame,,,,they would adapt to any angle and be heavy steel to boot,,drawing it on paper allowed front and rear angle changes and solid face mounting to the small motor mount bosses molded on the engine,,another thought on this is are the mounts big enough to drill through from the top and use quality bolts all the way through with nuts and lock washers against a solid steel plate from the other side
Old 06-24-2010, 12:44 AM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
If you drill too far into the mount you end up inside the crankcase.
Old 06-24-2010, 01:19 AM
BADBOOH's Avatar
I think your may be right about over torquing the seat tube nuts, however the front mount is definitly mounted as solid as anybodys! Any ideas of a better way to mount the seat tube half of the motor?
Old 06-24-2010, 01:40 AM
corgi1's Avatar
I was thinking removing the little studs and drilling side ways through the mount and bolting from the side all the way through with a steel plate on the other side with matching holes to tighten the nots against,sqeezing the oririnal mount between them
Old 06-24-2010, 04:44 PM
chainmaker's Avatar
chainmaker chainmaker is offline
I had a credit with MM for a mount,Last week I called the order in.I spoke to a very nice lady gave her all the sizes, etc she said about 2 weeks.
Cheers
chainmaker
Motorbicycling.com - The Ultimate Users Guide
Old 06-24-2010, 06:18 PM
Cheers
chainmaker
Good luck with that.
Old 06-24-2010, 06:44 PM
chainmaker's Avatar
LMFAO .... Yeah I know....I know others experience with the waits..but ya never know. Im still working on my bike not ready for motor yet. So I figured Id give it a shot. Looking for a back up plan anyone know somone else who sells a mount that doesnt look like muffler clamps. Im dumping alot of money in this bike and those ugly mounts will drive me insane..thats all I will see when I look at the bike
Cheers
Chainmaker
MotorBicycling.com
