Old 07-09-2008, 07:33 PM
captainrichhill captainrichhill is offline
Default Kill switch momentary "ON"????
How do ya wire the kill switch??? I connected mine so that the BLUE wire goes through the kill switch then to the coil. I had to hold the button in to get the engine to run. Any ideas??? Can I ground the coil wire (blue) somewhere???
I also have an annoying rattle in my exhaust. It sounds like there is a nut rattling around in the muffler. It even makes it when the bike is off and I shake the bike. Any ideas. I may have to cut it open and re-weld it.
Last edited by captainrichhill; 07-09-2008 at 07:36 PM. Reason: added more information
Old 07-09-2008, 07:50 PM
stude13 stude13 is offline
Default Re: Kill switch momentary "ON"????
hi hill; can-0-worms. on my rig a powerking the white wire goes to kill. hooking the kill wrong can fry your mag. there is a screw at the end of the pipe,remove pipe from barrel,
Old 07-09-2008, 07:54 PM
Dax 70 instructons say to use the blue wire. There is a screw at the end of the exhaust but it's also tack welded together. I would still need to cut the welds.
Old 07-09-2008, 08:37 PM
Bikeguy Joe's Avatar
http://motorbicycling.com/f4/how-wir...cycle-142.html
