Old 07-09-2008, 12:27 AM
Hicksy Hicksy is offline
Default Idle Screw Adjustment
Looked around the site to find an answer but no....
I've read and heard that the screw has to be out 4.5 turns. While fiddling around with it (trying to get the motor running smoother) I noticed that the only effect it has is increased revs from out 1 turn to fully shut (all the way in). It's a new engine.
What effect does this screw have and why would it only work out to 1 turn?
Should I adjust it within that 1 turn range?
Old 07-09-2008, 01:44 AM
stude13 stude13 is offline
Default Re: Idle Screw Adjustment
hi; you are right 4 1/2 out until later. it does not set the idle, it is adjusted at the top at the cable end. much more knowledge here. good luck. mitch
Old 07-09-2008, 06:59 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
After you get the cable length adjusted correctly the idel screw will actully do something.
Run it out to 4.5 turns then adjust the cable length to where you want it to idle. From that point on the idle screw should work fine.
Old 07-09-2008, 07:32 AM
Pablo's Avatar
Pablo Pablo is offline
Indeed it's a sign that something else (cable adjustment, air leak) is not correct.
Adjust the cable so there is just a tiny amount of slack in the sleeve (you know it's too tight when turning the bars changes idle speed, too loose when the twist throttle doesn't return (it'll be funky too tight as well) ).
Assure you have no intake leaks....use water or WD-40 or propane gas cautiously around the fittings, see if idle changes....
And bare in mind, idle can be funky until well broken in. It will change a lot as engine warms up.
Old 07-09-2008, 07:36 AM
You are incorrect sir!
The screw is for idle speed adjustment ONLY. They tend to be different lengths, so if you have it at one turn and it idles good, leave it there.
The adjuster at the top of the carb is for taking the slack out of the cable. You should adjust it until there is just a tiny bit of free play in the cable housing, then adjust the idle speed screw at the side of the carb.
Old 07-09-2008, 11:50 AM
misteright1_99's Avatar
All the idle screw does is hold the slide slighty open for idle, the farther in the higher the slide, the higher the idle. You should not use the adjustment at the top of carby for idle adjustment. As Joe says this is strictly for taking the slack out of the cable. 4-1/2 turns out is just a general starting point each engine will be different.
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
MotorBicycling.com
