Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Cruiser Bicycles
Motorized Cruiser Bicycles The beach cruiser has always been great bicycles to motorize. They just look good with a motor. Use this section to share and discuss about motorizing this classic.
Old 06-22-2010, 04:42 PM
freewheeling frank freewheeling frank is offline
Default Re: Replacing Coaster Brake wheel
can i throw in my cranbrook stuff? dont drill the frame,that was a big mistake for me,but pablo at sick bike parts has an adapter that works great and only costs a few bucks, good luck frank
Old 06-22-2010, 05:27 PM
Cabinfever1977's Avatar
Loosen the nut on the coaster brake arm while the wheel is still on the bike. The nut comes off easy.
Old 06-23-2010, 10:08 PM
grinNbarritt's Avatar
grinNbarritt grinNbarritt is offline
If it were me, I'd put brake on front. weight transfers forward when stopping so ya get more outa a front
Old 06-24-2010, 07:19 PM
xwint3rxmut3x xwint3rxmut3x is offline
Hey, sorry about the slow reply. I had to re-do alot of stuff, and wanted to make sure it was on point before I took my newb advice and sent you on a train wreck. Let's see, things worth noting.
1. It took superhuman strength to remove that bolt, I had one friend who was able to do it, 4 others tried and failed. Keep at it, it will come off.
2. Take the back fender off, or trim it, or put the front fender on the back. It will likely get in the way of the chain.
3. Make sure your motor and chain are straight with the sprocket....what I thought was noise from my chain hitting my fender (which i'd cut a chunk out of and just figured it wasn't sufficient) was actually my chain hitting my frame and slowly eroding a decent chunk out of it.
4. I'm still not 100% sure about this call, but I re-mounted the sprocket with the teeth closer to the spokes, as opposed to facing the way where the teeth were farther out. I haven't gotten a chance to ride it yet, but it looks like the chain is on straighter, and isn't in danger of hitting my tire or my frame anymore.
I apologize if any of this information is incorrect, i'm learning along with everyone else. If anyone wants to add or correct anything I said please pass it along. I've a long way to go still before I feel i'm even close to an "expert" on motor bikes.
