Old 07-07-2008, 10:20 PM
cdlale cdlale is offline
Default Clutch Question
Hello All
Is it normal to have a little bit of clutch squeal lasting about 2 seconds when the clutch is released while peddling when the engine is running?
Thanks
cdlale
Old 07-08-2008, 01:04 AM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: Clutch Question
1. How to Adjust Clutch if signs of slipping or squealing are encountered :
A) Disengage clutch by pulling handle bar clutch lever inward and lock into catch lock.
B) Remove right side engine clutch cover and remove small locking screw on center *Clutch Adjust Nut.
C) Pull clutch arm on left rear engine inward. Back off *Clutch Adjust Nut ¼ turn counterclockwise.
D) Release clutch lever and check for slight clutch arm 1/16” free-play on opposite side of engine. Readjust *Clutch Adjust Nut as required to get required 1/6” clutch arm free play.
E) Tighten *Clutch Adjust Nut on clutch plate clockwise until just snug.
F) Then re-install small locking screw in outer edge of *Clutch Adjust Nut.
G) Good idea to place a small gob of grease at gear mesh area. Use grease sparingly! Then replace cover.
H) Squirt light grade oil down clutch cable sheathing to reduce friction and make for easy lever pull.
Clutch adjuster nut
