Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Motor Bicycle Safety
Motor Bicycle Safety Share safety tips for motorized bicycles. Some of these bicycle engines will reach great speeds and need respect.
Old 07-07-2008, 05:32 PM
Tj Bunch Tj Bunch is offline
Default Lights Head and or Tail
theese guys make LED lights for everything, Some may find useful others not.
Thay don't look half as cool as Norms Lights but they Function.
LED Bike Bicycle Light Fixtures RV Rv'S
be sure to look at all of there products you may want some for your cars too.
Greg.
PS I got linky from one of my Jeep forums.....I'm not afiliated in any way just trying to help.
Old 07-08-2008, 01:24 AM
Dan's Avatar
Dan Dan is offline
Default Re: Lights Head and or Tail
Pretty cool, thanks Tj
I want 2 ride my bicycle
Old 01-28-2009, 02:22 PM
rickhymel rickhymel is offline
Hey, guy I have a problem I need light on my motor bike and i need to no if i should used a 6 volt or 12 volts. my engine size is 49cc. the brand is howell. can someone help me.
Old 01-28-2009, 02:24 PM
jasonh's Avatar
jasonh jasonh is offline
There are many threads covering this rickhymel. A simple search will yield what you're looking for.
The magneto generally puts out 6v, and you can have up to 3w without any negative effect on your ignition. 3w is not very bright.
Old 01-28-2009, 02:35 PM
thanks that help.
Old 01-28-2009, 07:26 PM
FileStyle's Avatar
I only run a single tail light from my white wire, it's plenty bright and can be seen from behind with ease! I run a rechargeable halogen bicycle headlight up front and is very bright indeed.
FileStyleCycles
Old 01-28-2009, 10:21 PM
were did you fine your light for your bike.
Old 01-29-2009, 10:47 AM
FileStyle's Avatar
ebay! I typed in mountain bike headlights and searched around a little. there are some really nice expensive lights out there! I settled on a halogen light for about $70.00 but you get what you pay for right! I found a real nice rechargeable headlight system on Ebay - nite rider mini led dual light system that are real nice. my partner in crime ,Hookworm has this set and let me tell you , it turns darkness into daylight! as far as the tail light goes, it come from a old dynamo kit and I just wired it up to a push button switch and then run it to my white wire. the light can be seen good in the daylight as well as night .
FileStyleCycles
