Old 07-05-2008, 09:26 PM
Howitt Howitt is offline
Default help solve problem
I am having a problem with my 80cc motor. When travelling at WOT the engine sounds funny. It has a nice hum to it but every few seconds there is a brief almost purring sound. I also seem too lose and gain speed while maintaining the same throttle position. Does anyone have a suggestion to a possible cause?
Old 07-05-2008, 09:33 PM
gadgetman80 gadgetman80 is offline
Default Re: help solve problem
Is this when it is cold/warm/hot? When I was messing around with nitro r/c cars, I noticed when they got hot and the mixture was lean, they'd fluctuate at WOT. Keep in mind, I don't have one of these engines "YET", but if I'm off base I hope someone can correct me.
Old 07-05-2008, 10:02 PM
Ilikeabikea's Avatar
Mine does that too. A wot it fluctuates. Norman soldered and redrilled my main jet yesterday. I've been having lots of company over the weekend so I haven't really got to try it out yet. I rode it once yesterday but didn't have time to let it warm up good. As soon as I can really ride it I'll let you know how it does..............................
Old 07-05-2008, 10:10 PM
stude13 stude13 is offline
my guess is lean, dont run wot till you figure it out
Old 07-06-2008, 01:41 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I think your fuel mixture might be fluctuating between slightly rich & just right.
My "Bomber bike" was doing the same thing!
Try dropping the carb needle down one notch, (C-clip UP one notch) & see if that helps.
Also make sure to upgrade your spark plug, wire & boot, & solder your coil wires!!
Old 07-06-2008, 11:52 AM
I moved the clip up one notch but the same problem is happening. I am going to go out and replace the plug and wire today. I was reading some other posts and I'm thinking that the problem might be caused by the main jet being too small, I think replacing it with a larger one ( .80mm ) might solve the problem.
Old 07-06-2008, 01:04 PM
imdhulk imdhulk is offline
i desperatly need help... i finally put together my moter kit.. i rode it for 2 days with no prob.. this morning i tried to get her started but she wouldnt start... i peddle to get the motor runnin but it just wont start..can some one please give me advice before i lose my mind.. im not miachanically incline.. i dont know what the **** im doing... my brother inlaw put this gadget together..and has no time to help.. he said to come to this forum.. can some one please help
Old 07-06-2008, 01:26 PM
i just finnished putting my motor kit togather.. rather my brother in law did.. it was runnin for two days ... i tried to get her started but she wouldnt... i peddled my buns off but no start.. what can be the prob... i m not mechanically inclined. i do not no where to begin to look for the prob. can some one please help me befor i lose my mind.
Old 07-06-2008, 04:05 PM
Dave31's Avatar
Dave31 Dave31 is offline
The first thing you can try that's the easiest is diconnect the kill switch..some of these switch's will ground themself's out.
If that don't work, you want to check for spark...before you do that check all you wire connection's for the CDI and make sure they are still connected.
To check for spark I use a spark plug ignition tester..
This can be picked up at any local auto parts store...you can also make one with a good plug...alligator and just solder the clip to plug
Norman has a cool one that is much simpler to make...
http://motorbicycling.com/f4/tester-ignition-207.html
Be sure to pull the plug out to turn the motor easier...or just pull your plug and hold it next to the motor to check for spark...this is a little hard for me since you have to hold the plug and turn the motor at the same time..
If you got spark...then you need to see if you are getting fuel....crank the motor for a little bit then pull the plug out and see if it's wet with fuel.
If not...check the screen in the petcock...check to be sure float is not stuck in the carb bowl..
hope this help's get you going
Old 07-06-2008, 04:18 PM
If you didn't put an inline filter on the fuel line you could have trash in the carb. These tanks can have crud in them. Check the simplest stuff first. If you don't have fuel and fire it won't run................................
