Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Heads and Cylinders
Heads and Cylinders All about your porting, compression, rings, cylinder and piston modifications to your bicycle engine
Old 07-03-2008, 10:57 PM
Pablo's Avatar
Pablo Pablo is offline
Default Best source for 8 mm head studs...
Where is the best place to buy good 8 mm head studs for a 67cc CG/HT engine?
Two of mine have ruined threads on the top side. Just when she was running so nice.
Old 07-03-2008, 11:30 PM
misteright1_99's Avatar
Default Re: Best source for 8 mm head studs...
I have heard mcmaster carr mentioned........
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
stude13 stude13 is offline
hi paul ive got more all thread than i need. ill meet you in fall city tomorrow if you want, ordered 6mm all thread yesterday. mitch
Old 07-04-2008, 12:17 AM
Pablo's Avatar
Not sure what our plans are for tomorrow....I thought full threads weren't kosher - but it's got to be better than the China junk!
Old 07-04-2008, 06:36 AM
Walter F.'s Avatar
Walter F. Walter F. is offline
You got Fastenal stores out there Go to Fastenal.com The got long threaded bolts whack off the head or forget studs use bolts, I'm replacing all Chinese bolts,studs,screws & nuts. You saw how "advanced" Chinese metallurgy is with a certain gas petcock eh Pablo? Walter F.
Old 07-04-2008, 06:43 AM
Pablo's Avatar
The head studs were the only studs I had not replaced!! Gotmee.
Don't forget the washers.
Old 07-04-2008, 10:50 AM
Skyliner70cc Skyliner70cc is offline
Banned
Pablo,
Did you use acorn nuts on your head studs? I find that these commonly damage the threads on our engines.
Old 07-04-2008, 10:57 AM
Pablo's Avatar
Originally Posted by Skyliner70cc View Post
Pablo,
Yes. I AM an idiot. I just kept thinking: Someday I'm going to get some nice 8mm nuts....
Now I will!
Old 07-04-2008, 12:10 PM
Banned
Now I will!
No, you aren't. I also learned the hard way about acorn nuts and many other issues that can go (doesn't mean they will) wrong with our chinese 2 stroke kits.
Here is a tip that is risky to fix your bike without having to buy new studs. If you have a thread die, clean the stripped thread out with the die and then install the stud reversed but definitely JB weld the stud on the bottom. Reversed install means damaged thread are screwed/jb welded into block. A cheap quick fix to get you back on the road but I would understand perfectly if you wanted new studs.
Old 07-04-2008, 02:59 PM
hi paul; i went to fastenall in n.bemd for my all thread a stick of 6mm and 8mm is only about twelve bucks, i cut it with a dremel and then double nut to insert stud, denut, add lock washer and one nut torque and double nut. i had already purchaced the nuts and washers at true value. we dont have tractor supply co. in washington, but dels tractor supply is its subsidiary, they have the rubber roller parts for that nice chain tensioner. we can meet anytime and ill get some oil too. mitch happy 4th
