Old 05-10-2010, 07:36 AM
beentryin's Avatar
beentryin beentryin is offline
Default Re: whistling motor
Originally Posted by psprat496 View Post
Oh, we'll that's most likely the sound of your clutch engaging. When you pull your clutch is it easily pulled or stiff?
its alway been kinda stiff,but its a smooth stiiff if you know wat i mean.i greased the small gear a few days ago,do i just pull the bar out and put grease on it?
Old 05-10-2010, 07:58 AM
demac demac is offline
it honestly just sounds like the clutch cover, where the gears are located. trying holding your hand on it, hear it that dampens the vibration. You can buy a cover that dampens the noise and wont hear a screech or whistle. ""sickbikeparts"" pretty sure.
Old 05-10-2010, 09:11 PM
corgi1's Avatar
corgi1 corgi1 is offline
Yes ,just a mild greasing ,all over it............Idle was why I thought of the bucking bar and ball ,under the cover w/the clutch lever in the center of the drive gear,,,a clutch cover damper (above) sounds good too.......If it doesn't stop,you might try small squirts of WD-40 where the intake manifold bolts on,, and carb. conector,etc looking fot a whistling air leak.
