Old 07-03-2008, 12:50 PM
Bikeman08 Bikeman08 is offline
Angry No Spark
really getting frustrated, i have no spark at all what shall i do guys?? I took the plug out and laid it in the head lifted the rear end of the bike and turned it over i saw no spark at all. The stock wire that came with the bike was to small for the tip of the plug NGK(B5H5) so I went to the auto part store and got a wire. screwed the wire onto the ignition unit and the other end to the plug still nothing. I dont know what to do. I even poured a little fuel/oil mix direclty in the cylinder and still no fire. What next?????
Old 07-03-2008, 12:55 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: No Spark
your wires all connected and tight at the cdi no bare wires shorting things out you also using a copper core sparkplug wire plug gapped at about 0.017 even though the instructions say 0.028
New clean plug?
last ditch effort hold on to the plug wire and turn over the engine if you have spark it will be a shocking experience. Don't do it if you have a bad heart get a kid to be the sucker/I mean tester.
Norman
norms-iron-works.tripod.com
Old 07-03-2008, 01:02 PM
ok norman thanks but what kind if wire do you have cause the one that came with my kits sucks so i bought a automotive one and kinda rigged it.
Old 07-03-2008, 02:11 PM
Bikeguy Joe's Avatar
7mm screws it into the CDI. Unhook your kill switch.
Old 07-03-2008, 04:54 PM
Norman's Avatar
I run the stock china plug wire with no problems on 2 bikes. And one bike I do have a industrial copper core plug wire with a racing kart plug boot that does not require that the top tip of the plug unscrews.
Norman
Old 07-03-2008, 06:22 PM
Bike guy joe what do you mean 7mm screws??
Old 07-03-2008, 08:01 PM
misteright1_99's Avatar
7mm wire screws into the CDI unit, and into the stock plug cap.........
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 07-04-2008, 10:49 AM
Thank you.
Old 07-04-2008, 01:05 PM
Anytime....
Old 07-13-2008, 11:38 PM
Tj Bunch Tj Bunch is offline
what was the outcome? i have similar problem
