Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 07-02-2008, 11:14 PM
tripodcomputerservices tripodcomputerservices is offline
Thumbs down DIY motorized bike missing gear
I have a Giant Revive. I have found a good electric motor from a scooter that is a small frame and have everything that I need to make a pedal assist bike. I am unclear as to what gear I need for the motor. I know that I need one with a couple set screws but the gears that I have found online are called #25...
What gear for a bicycle chain do I need to complete this? The shaft for the motor is about a 1/4 inch in diameter. I am placing the motor in front of the pedals and running the chain from the front gear over the motor shaft with this gear on it... the one that I do not have...
Any help is appreciated.
Old 07-03-2008, 12:47 AM
Easy Rider's Avatar
Easy Rider Easy Rider is online now
Santa Cruz Scooter Works
Default Re: DIY motorized bike missing gear
I think the 25 stands for the chain size. A 25h or 25 chain is used on electric scooters. If that's the case you could use a large pocketbike cag sprocket. Pipelyne carrys a bunch of those sprockets with lots of different sizes.
Old 07-03-2008, 12:55 AM
I am putting my motor inline with the chain that is already there... it is intended to be a peddle assist. Do you know what number the chain that is on a bicycle is? If #25 is a pocket bike, does a regular bicycle have a certain number? I look and see that my chain is just the same as all 10-26 speed bikes as in the size but before ordering the sprocket for the motor, I wanted to make sure that i have the right one. Thnks for the site information btw. I will look there now.
Old 07-03-2008, 01:09 AM
well, I may have answered my own question. I went here 1.5.1 Bicycle Chain to see that the chain pitch is 1/2 inch and went here Tooth Dimensions to see that the 1/2 inch pitch is a chain number 41. I am wondering if this is correct?
Old 07-03-2008, 06:50 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
the width of the sprocket will be thicker on a 41 than a bicycle chain. I have never seen a number for a bicycle chain to be honest. They are just 1/8 x 1/2 or maybe it is 1/2 by 1/8 mtb chain is a little thinner. 3/32 I think. If you weld you might just weld a bike's rear sprocket to the drive of the elec motor. You would have to weld a washer to the rear sprocket to decrease the size of the hole, then weld the washer to the motor hub.
Personally I would just use a friction drive. But then I'm less mechanical than most here.
Old 07-03-2008, 07:58 AM
Bikeguy Joe's Avatar
There are two basic bike chains "Single speed" and the type used with a derailuer.
Old 08-26-2008, 12:54 AM
Goat Herder's Avatar
Gutter Rider
Not fretting at you Joe but Between a 5speed 9speed is a differant chain size. Somthing about the added sprockets in the rear, the extra steps in the sprocket sizes on 9is diff than the 8 through 5. [ for the derailer that is]. Requiring differant chain size. Funny though you can use the same front sprockets in all cofigerations of chains, and rear cassets.
Last edited by Goat Herder; 08-26-2008 at 01:07 AM. Reason: left out I was refering to the derailer
Old 08-26-2008, 01:03 AM
Gutter Rider
O i got that wrong Chain diff changes at 9 tooth sprocket. for derailers. If I remmember right
Old 08-26-2008, 07:51 AM
deacon's Avatar
Just for some additional confusion, if you decide to switch out the rear wheel of a mountain bike for a coaster wheel. A good think if you mount an engine on the rear wheel and lose the brake, you can use a coaster chain on the slightly smaller front sprocket set, I put mine on the middle sprocket. It helps to keep it from jumping ship I think.
Just some useless trivia.
