Old 07-02-2008, 07:36 PM
Papabear86 Papabear86 is offline
Default Getting really frustrated with my EBAY purchase
I just bought a Power King engine kit on EBAY and am having a really tough go of it.
I received everything later than anticipated (that is not a big deal) and have been working on the engine kit for 3 days.
My son is supposed to ride the bike in a parade on Friday, July 4th, and I get the dang thing to work.
Has anyone here ever worked on one of these kits.
Its a 70cc engine (or so I was sold), it has a motorcycle chain that would pull a house, its instructions are nice and polite but inadequate and I have no clue how the clutch assembly is supposed to operate.
Desperate Dave!!
Old 07-02-2008, 07:44 PM
Bikeguy Joe's Avatar
Default Re: Getting really frustrated with my EBAY purchase
Read this. http://motorbicycling.com/f30/bicycl...-care-354.html
After you read the next post....
Old 07-02-2008, 07:52 PM
Dave31's Avatar
Dave31 Dave31 is offline
A) Install clutch lever to left side of handlebar and attach cable end to lever.
B) Squirt oil down the cable sleeve: Route clutch cable through the ball-mount on motor with the big spring around the cable jacket and ahead of the ball mount. The big spring serves as a cable heat shield.
C) Insert cable wire through small spring and route through clutch arm and attach brass cable-end and screw. Adjust cable tension to allow very slight play in arm. Handlebar clutch lever or twist clutch must be in the released or outward position to complete this operation
D) Activate lever a few times, and check clutch arm for slight free play: About 1/16” free play is OK. Re-adjust if needed. Basics of clutch operation: The clutch lever pulls the cable that moves the clutch arm. In turn the clutch arm pushes a rod through the motor that pushes the clutch plate. ( similar to a car clutch.)Releasing the clutch lever engages the engine torque to the drive chain. The clutch allows engine to start, and engage or disengage engine torque to the drive chain. When the bike is in the pedal mode the handle bar clutch lever is locked inward in the catch notch. The bike then operates in default as it would without any engine.Periodic clutch adjustment is necessary to maintain efficient operation
Cut of excess cable from clutch arm to avoid any interference
Old 07-02-2008, 07:57 PM
Thank you, my clutch wont move in the direction as that picture, possibly my assembly is too tight.
I took apart the assembly to get the chain on there, its a thick one, and I cannot get the sprocket to move. I replace the clutch assembly and still cannot get the sprocket to move. There is ample grease on it and it will move the engine with the tool that came with it, but it wont move otherwise.
Any suggestions would be appreciated!!!
Old 07-02-2008, 07:59 PM
I actually think this would be a fun business since so many parking spaces are being removed from campus while enrollment continues to increase. $4.00 gas makes it appealing also.
Old 07-02-2008, 08:06 PM
Dave31's Avatar
Are you trying to move the clutch arm by hand?? It is very dificult to almost impossible to do it that way..
Old 07-02-2008, 08:22 PM
I have even more of a mess now, my dad tried to thread the chain without removing clip and it is now stuck, Lovely.
That is what I get for having an Engineer for a dad
Old 07-02-2008, 08:35 PM
misteright1_99's Avatar
Take the spark plug out and use the sprocket/ sparkplug socket that should have come with kit. Start the chain on sprocket, the use the socket on the sprocket nut to turn the sprocket to thread the chain.....
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 07-02-2008, 09:07 PM
great idea misterright
thank you sir
Old 07-02-2008, 10:12 PM
OK, taking the plug out was the key. Now that I have the chain off I can see that it rubs the tire. There is a rubber wheel that is supported by the frame that I assume is for the benefit of the chain. Is this item for the upper or lower chain? Would installing it keep it from rubbing?
