Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 2 Stroke Bicycle Engines & Kits
2 Stroke Bicycle Engines & Kits 2 stroke engine kits need careful installation and setup, find out how from our professionals here!
Old 04-29-2010, 06:48 AM
Charged-Reacter's Avatar
Charged-Reacter Charged-Reacter is offline
Default PK-80 cold start ups
I purchased my first mountian bike and it was a cheap Roadmaster alunimin made frame
6-speed and a pk-80 engine. To start up you stand up to peddle and bump your butt on the seat
and it takes right off. A very easy start up.
The other pk-80 is on a steel frame 7- speed bicycle. To start this one up - you have to
peddle your legs off. A very hard start up. Does anybody know why these start ups are different?
Old 05-19-2010, 10:15 PM
mojoman288 mojoman288 is offline
Default Re: PK-80 cold start ups
It could be because the steel frame is heavier than the aluminum one, or you might just need a new spark plug, I would advice opening up the engine to see if theres any problem, if you have a list of the parts, check each part to see if its all working.
A quick tip: Use BLUE Loctite on essential threads, it makes sure they are in there tight, and will allow for repairs
Best of luck, ride hard, Mojoman.
Old 05-20-2010, 06:11 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
about the only tune up you can do to one of these is the spark plug I think. I would experiment with choke setting each one starts a little differently. Also the tickler thing puts more gas in on some models than others. In other words they don't all start exactly the same I have heard. One of the reasons I went electric.
Old 12-01-2010, 04:38 PM
mobike91's Avatar
mobike91 mobike91 is offline
sounds like you need to ajust your clutch
every run is a test run . . . and i just hope it dont blow up - wil
Old 12-01-2010, 08:43 PM
silverbear's Avatar
silverbear silverbear is offline
The Boy Who Never Grew Up
I have a pk-80 on a bike I built at the end of the summer (Firebird, Silverbear's Worksman Cruiser is what the thread is called) and it is a nice motor. I didn't have a chance to ride it much as I got involved in other builds, but I did notice it was cold blooded. It took a good bit of choke to get going when a couple other two strokes didn't require any. It may be that as it breaks in that will change. I hope so as it is a powerful little motor. Other than the hard starting I think it's a winner. If you learn anything, pass it along. I wonder if the iridium plug would make a difference.
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
Old 12-02-2010, 06:47 AM
The PK-80 engine on the steel frame bike did not have the clutch
arm adjusted right. Noticed that when bicycle was running and idleing
with clutch handle pulled in and raising back wheel off the ground, the
tire would spin. Corrected that and cold start-ups got easier.
Old 12-02-2010, 02:46 PM
Mind_Reader7's Avatar
Mind_Reader7 Mind_Reader7 is offline
It's most probably the fuel float arm. When mine was overflowing, it would start right up, when I bent it a bit, it sputtered to life. I changed the engine to another bike, on a lower angle and now I gotta prime it a fair bit, and even then it takes a bit to start (should prob bend em back).
Old 05-09-2011, 02:42 PM
rat racer's Avatar
rat racer rat racer is offline
CHANGE the carburetor you will get a much smoother running engine and easier starts
the cns performance carb works very well also the delorto and chinese knock off delorto work well also the cns carb comes with a handle bar mounted choke.I am running a cns carb with a uno foam motorcycle filter....no restriction
and works very well
I am building a 66cc boost ported cly engine with walbro carb and reed valve
hope it boosts hp.
Old 05-25-2011, 07:30 AM
Mr.Gadget's Avatar
Mr.Gadget Mr.Gadget is offline
I am having a similar issue, but I believe mine is more fuel related. The clutch is adjusted properly, no issues there. Mine is a HARD cold start, but once she fires up, runs strong as I could hope for. I'm going to go over my fuel set up this weekend, and post any findings as to why mine became such a hard start when it's cold.
Watching my kids enjoy what they have learned and built, is why we started MB'ing
Old 05-26-2011, 12:37 PM
Mr.Gadget's Avatar
Well, I did it.
I pulled the fuel shut off valve, and found that the guy before me reassembled it wrong, this was letting fuel over fill the bowl, and flood the carb. My filter was dripping wet, and the cap for the cable and slide assembly was stripped and not holding everything together very well.
So....... rebuild the shut off valve so when I turn it off,, it actually stops fuel flow. Dried out the filter, cleaned out some gunk at the bottom of the bowl. Then I replaced the slide assembly cap with a spare out of my parts box.
Re assembled everything, filled it with my new mixture of 32:1,,,, and she fired right up. Just like my other bike. Ride down the driveway to the street, pop the clutch, and Was on my way.
I really felt that it was a fuel problem,, and after the things I found, thats what it was, a flooded carb.
Hope this helps someone out in the future.
Have fun, and keep safe.
MotorBicycling.com
