Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Old 06-29-2008, 07:54 AM
Bikeman08 Bikeman08 is offline
Default Chain Slippage
Has any body had the problem when you peddling in the high gears 1/2 the chain slips. It sucks very bad any quick fixes please thanks Yall
Old 06-29-2008, 09:02 AM
Jemma Hawtrey's Avatar
Jemma Hawtrey Jemma Hawtrey is offline
Default Re: Chain Slippage
We need more information specially about what transmission system you are using - eg 3x7/8/9 deraillier or Hub gears or even a mixture. I have heard of bikes where the transmission has been 3x14 using a rohloff hub and MTB front triple crank... but that to my knowledge has never been made as a standard offering.
You might try checking that the chain is correctly tensioned and also clean and lubricated (crap in the chain will cause it to jump)
Also have the bike on a stand or upside down and pedal in the higher gears using your hands - that will give you an idea of what is happening when the problem occurs which will also give you a clue to why.
If its a deraillier system the control cables might need adjustment because they stretch over time a little and with the 7-8-9 spd cassettes a little stretch can cause all sorts of problems because the amount of shifter movement between ratios is so minimal.
If you are using a hub system (at least a shimano, like I have) you check cable alignment by putting it into the middle ratio on the shifter (in my case '4') and then looking at the selector on the hub itself you are looking for two red dots to be in line with each other... if they are not you need to make the relevant adjustment to ensure that is the case and no more slop.
In the case of the hub system the feeling resulting from misalignment is similar to the effect you get when a manual clutch is slipping in a car.. it seems to jump and judder under load.
"....Look, no pedals... *thud*..." The mating call of the motorized-biker.
"RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork.
Old 06-29-2008, 10:49 AM
WOW thats a lot to asorb IM new in the bike world so im sure i will have plenty of questions. Thanks for the info but im a little confussed. Any websites or books you recommend.
Old 06-29-2008, 10:55 AM
Flightline One - HARO
here are the specs for my MTB
Old 06-29-2008, 11:23 AM
Pablo's Avatar
Pablo Pablo is offline
How To Adjust Your Rear Derailleur - The Bicycle Tutor
http://bicycletutor.com
Bikeguy Joe's Avatar
Derailer Adjustment-How To
Old 06-29-2008, 11:24 AM
Nice bit of info Jemma!
Old 06-29-2008, 11:25 AM
I think you are gonna run into some problems mounting up your bicycle motor kit to that bike...
Old 06-29-2008, 02:32 PM
stude13 stude13 is offline
hi; where are you? go to search and enjoy.
Old 06-29-2008, 11:19 PM
Hi Bikeguy thats not the bike im going to be mounting i have a GT MTB awaiting the install oh "YEAH" cant wait kit should be here soon.
