Old 04-09-2010, 01:54 AM
meowy84 meowy84 is offline
Default What spark plug for my 80/66cc engine?
Hello y'all. I'm in the final stage of installing my engine kit. It's the 80cc slant plug engine kit from Zoombicycles.com. Anyways I figured I might as well get a good quality plug to replace the original Chinese one. Any recommendations? I'm looking for a good all-around plug wih the proper heat range so engine won't foul. I'll be using the bike for general commuting and just bombing around, not all out speed trials (LOL) so need something that will operate good a idle as well. Any tips/help would be appreciated.
Old 04-09-2010, 02:03 AM
AaronF's Avatar
AaronF AaronF is offline
Default Re: What spark plug for my 80/66cc engine?
A NGK Spark Plug is a great replacement for these engines such as a NGK # BPR6HIX OR a NGK # BP7HS Advance Auto usually has a larger selection of plugs so you could check there.SBP also carries both of these plugs at a good price. Have fun!
Old 04-09-2010, 02:54 AM
BarelyAWake's Avatar
By far the most common plug used to replace stock is the NGK B6HS, the NGK BPR6HIX Aaron recommended is the fancy iridium one, the BP7HS is an extended tip plug with a cool heat range
Old 04-09-2010, 11:09 AM
Venice Motor Bikes's Avatar
Use a NGK B5HS or a B6HS... The #7 is way too cold! (NGK #'s are 1= hottest)
Follow VMB on facebook>>> facebook.com/VeniceMotorBikes
Follow VMB on Instagram>>> instagram.com/venicemotorbikes
Old 04-09-2010, 07:26 PM
Great! Thanks for the info guys. Greatly appreciated.
Old 04-09-2010, 07:35 PM
ZRTMWA ZRTMWA is offline
I have the iridium BPR6HIX, I never used the stock plug so I can't really compare it to that, but it runs great. What exactly does extended mean? Extended into the motor or larger spark gap? The iridium actually has a bigger spark gap (@ .032") than the BP7HS (@ .027").
Yes, NGK recommends for every 100 horsepower added you should get one level cooler plug. With Japanese plugs like NGK, the higher the level the cooler the plug.
Old 04-21-2010, 03:54 PM
Venice mentioned using either the B5HS or a B6HS plug. What's the difference between the two? I assume the 5 or 6 refers to the heat range? Since I'll mostly be running my bike in the city I'll be running at at low to mid-range speed rather than all out. So which plug would be recommended for that type of riding?
Old 04-21-2010, 05:09 PM
stuartracing's Avatar
stuartracing stuartracing is offline
I`m here in fl. and run mine in the city like you do but I use a B7HS without any issues whatsoever....The higher the number the cooler the plug...I beleive a B6 is what the stock plug cross`s over to.....You aren`t going really notice a HUGE difference buy going one step colder/hotter plug...If you go extremly hot on the plug it WILL burn a hole directly though the piston.....But with these motors you could go from a B5HS to a B7HS and not really notice a thing....IT won`t make your motor run colder or hotter....I have a billet head on another one of my bikes which bumped up the compression quite a bit and am running a B8HS NGK plug.....
So just run the NGK B6HS and you should be just fine until you get more performance upgrades done......MY 2 CENTS WORTH.....
Life in the Fast Lane......
If your living on the edge , you`re taking up too much space....
Old 04-21-2010, 07:22 PM
flybytaco's Avatar
flybytaco flybytaco is offline
Metal Molding Madman
what billet head are you running a b8hs?
the evader
Old 04-21-2010, 08:09 PM
The one from Pirate Cycles made by Creative Engineering.....
Nice cyl. head.....
MotorBicycling.com
