Old 06-26-2008, 03:18 AM
WINDSHIELD WINDSHIELD is offline
Default some problem with my small 4stroke
Hello.I have a robin subaru 33cc 4 stroke on my bicycle.I leave the bicycle without use for about 8 months.Right now when i try to run the motor dont start.Someone knows some good tricks?I need to use carburator cleaner?a new spark?Thanks for the attention.
Old 06-26-2008, 06:47 AM
Bikeguy Joe's Avatar
Default Re: some problem with my small 4stroke
Drain the gas out of your tank and carb. Not sure what kind of carb you have, but it would be a good idea to clean the carb, or at least the float bowl. Run the proper amount of Sea Foam or other carb cleaner in the gas for a tank or two.
Keep us posted whether you get it running or not.
Next time you are gonna let it sit, use some Stabil fuel stabilizer.
Old 06-26-2008, 12:09 PM
jasonh's Avatar
jasonh jasonh is offline
Don't forget you should also change the oil after letting it sit for so long.
As Joe said, clean the carb. New spark plug would help if the current one is gunked up.
If you're going to let it sit again, I would drain the gas before putting it away.
Old 06-26-2008, 04:51 PM
Thanks for the help.I need to change oil no matters if the motor have amsoil syntetic lubricant?This type of oil also get old if the motor dont run for a long time?
Old 06-26-2008, 07:42 PM
It may be O.K. I'd still change it after you gewt it running again and put afew miles on it.
Old 06-26-2008, 10:06 PM
Pablo's Avatar
Pablo Pablo is offline
The oil is probably OK but how long are we talking about? It could have condensate (water) in it - depending where you live and how it was stored.
Most importantly is fresh fuel.
Old 06-28-2008, 02:41 AM
Hello.Thanks for the help.The problem was the fuel.I was drain the 1 liter gas tank plus spray carb cleaner inside the carburator,very little amount.First the engine runs sluggish but when i pump new gasoline inside the carburator from the small pump it works well.Next i drop about half ounce of mystery oil(this is a fuel cleaner) inside the gas tank.Fuel additives are good for small motors?I was read an article that recomends to mix with gasoline some kind of oil just to lubricate the internal parts of the motor at every moment the tank is fill.That because the gasoline itself cant lubricate small motor parts.Someone with some knowleadge please let me know.Thanks for the attention.
Old 06-28-2008, 07:41 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
You HAVE to mix oil with your gas in these two stroke engine or it will seize. You should have the proper gas/oil mix ration and use only that in your engine.
Old 06-28-2008, 08:02 AM
My motor is a 4stroke robin subaru.Thanks for the help.
Old 06-28-2008, 08:08 AM
No need to mix oil...though a bit of Marvel Mystery oil is O.K.!
