| Heads and Cylinders All about your porting, compression, rings, cylinder and piston modifications
to your bicycle engine |
06-24-2008, 09:08 PM
Machining the head/ Boosting compression
I am considering machining the top of the cylinder (the head) down by a millimeter or two on a lathe to boost compression. Has anybody tried this? There is a bloke from Australia who has apparently with success.
Shouldn't be too difficult and should work fine... bit of a risk tho! Hmmmmm
06-24-2008, 09:10 PM
Re: Machining the head/ Boosting compression
Here is the link... Check out "Lisdale Flyer" what a BEAST!!
ZBox engine innovations 2008
06-24-2008, 11:54 PM
I was just thinking about this today, wondering if it could be done.
06-25-2008, 06:57 AM
Shouldn't be too hard Just take the cylinder to a metal turner. I think it would be a good idea to tread cautiously. The extra compression might rip a head bolt right out of the engine block! I stripped the engine block thread just by over tightening a while back, luckily I had it heli-coiled back in place
06-25-2008, 08:28 AM
I don't know about a "mm or two". That would be a bit excessive.
3mm would be 1/8th of an inch!
Math for the Toolbox. SAE to Metric Conversion.
06-25-2008, 09:49 AM
Back in the day we would surface grind or mill heads.....dunno about the head in a lathe....
06-25-2008, 10:51 AM
Norman has a piece of glass with sandpaper glued to it that he uses. It removes metal real nice and slow. He keeps it wet and soapy...................
06-25-2008, 10:55 AM
That's where I'm going, the Norman way!!
06-25-2008, 11:09 AM
Santa Cruz Scooter Works
We done a few and the best one we did was around 70 thousand of an inch. We even redomed one and it works for a little bit but we found out the the head bolts (which are made of cheap metal) stretches. Then leaks and blown head gaskets occur.
06-25-2008, 11:41 AM
More good info. Note to self, get new studs.
| Thread Tools |
| Display Modes |
Linear Mode
