Old 03-20-2010, 03:30 PM
ZRTMWA ZRTMWA is offline
Default Dual Brake
I have this Dual brake/ Throttle/ Killswitch combo:
and here:
Does anyone know how I'm supposed to attach the cables to it?
I have these brake cables with the barrel type ending:
If you look closely at the first pic, you can see there is only a tiny hole for the cable to go through. I'm guessing I have to cut the barrel off and somehow tie a knot in the cable at the end?
I just uninstalled my brake cables from their original holders and then put them back into their original holders but the was way too much slack. How would I adjust this??? I can't figure anything out with these brakes...
Thanks
Old 03-20-2010, 07:55 PM
corgi1's Avatar
corgi1 corgi1 is offline
Default Re: Dual Brake
Do you pull the cable out of the housing and thread it thruogh the handle ,etc and back thhrough the cable housing?,,,I see one end of the cable is not got an end on it,and I would start with that.
Old 03-20-2010, 08:56 PM
rockvoice's Avatar
rockvoice rockvoice is offline
the barrel attatches to the handle itself then while holding the handle open the cable feeds through the back side of the housing to the front
Old 03-20-2010, 10:13 PM
So for the rear brake, I have to detach the cable at the rear brake, back here?:
Then I have to feed the whole thing back through the dual pull brakes, cable sheaths, etc. and to the back again?
What about getting rid of slack? After I simply detached the brake cable from the front left (rear) brake and put it back in, I could literally squeeze the handle all the way in and get no braking power... I don't think I even changed anything.
Old 03-22-2010, 03:52 PM
Nougat Nougat is offline
Wow, that's a funny brake handle.
To get rid of the slack, you change where the cable is tightened down at the brake end. Do this with the adjuster at the handle screwed all the way in. You might have to fool with it a bit to get it tight enough, but not so tight the brakes rub on the wheel without braking.
Once you get that, you can screw out the adjuster at the handle side a little bit to fine tune it.
Old 03-22-2010, 09:35 PM
Yeah I'm not using the dual brakes b thanks for telling me how to get rid of slack because my rear brake is still messed up.
I failed to realize before that my brake handles are permanently attached to my shifters. There's no way I'm taking my shifters off and theres no point in just moving the cables to one handle if I'm still gonna have those other two annoying handles wobbling around loosely.
So far all I have left to do is fix my brake and my rear derailluer, add my chain, JB weld the fuel tank to the frame and adjust my clutch and my MB should be up and running. Expect pics!!!
Old 01-05-2011, 08:48 PM
2door's Avatar
2door 2door is offline
Are you certain the brake lever and shifter are integral? I've not seen this but I have seen them installed close together so that when looking at them they appear to be one unit. Look for a small set screw that holds them in place on the handlebar. It just might be that they are in fact two seperate parts.
As for adjusting your brakes: Slip a piece of sheetmetal, about 1/16" thick betwen the brake pads and the rim then pull the cable tight enough to clamp the pads to the sheetmetal. When you remove the metal your brakes should have just enough clearance so they do not rub the rim. Fine adjustments can then be made at the handlebar by turning the adjusters in or out.
As for mounting your fuel tank, do not rely on JB Weld (glue) to keep it in place. A better method would be to use a good quality double sided tape on the top tube and the mounting straps and hardware that came with your kit.
Old 01-06-2011, 05:07 AM
breno's Avatar
breno breno is offline
Unrelated but nice combo when ya get it goin.. dual brake lever is def. the way to go just simplifies everything I even went to the point of pulling all the gearing out I still got the sbp crank left on there and a derailer on the back single sprocket if I ever did want to go to a lower peddling gear I just gotta move the chain by hand and the derailer takes the slack. Sounds like a P.I.T.A but ya dont really ever peddle anyway so its all good IMO. Dunno if u wanna go that far but yeah I love the look of just 2 levers and a throttle, just looks like a big bmx.
-> Reading this signature was pointless <-
