Old 03-18-2010, 12:32 AM
KennyPowers KennyPowers is offline
Default Where is the best place to ground at??
Heres a dumb newb question. I am having a problem in killing my motor. I ground the ground wire to the chassis and the motor. Doesn't die.
Old 03-18-2010, 01:02 AM
michaelgrav's Avatar
michaelgrav michaelgrav is offline
Default Re: Where is the best place to ground at??
Ahhhh Just choke it!!
Old 03-18-2010, 05:19 AM
BarelyAWake's Avatar
If yer running some sort of padding between the engine mounts and the frame it may not be grounding itself - even if your not such a passive ground isn't to be trusted as there's paint and stuff so connecting both the ground from the engine and the one frm the switch is the way to go (water bottle mount works well for the engine ground if ya have one).
Odds are you've just got a funky switch - they're pretty much junk. Although mine works well, many have complained of problems with them. If you've got a multimeter ya outa check that switch - if ya dont, make one w/a battery, a hunk of wire and a flashlight bulb.
If the switch is hinky sometimes you can fix them w/a lil surgery, or better yet check ratshack fer one that's about the same size (Radio Shack, "momentary on" switch) - or just put a toggle anywhere convenient...
or as michael mentioned - jus' choke it to death FTW
