Old 03-17-2010, 07:23 PM
hiker472's Avatar
hiker472 hiker472 is offline
Default Grease leaking out of bottom of engine
I don't suspect that this is normal, but I have a grayish grease leaking out of the rear of the engine.
I took it for my first ride of the season today and when I had put it away to give it a good look over, I noticed it on the seat tube below the engine. It comes from under the engine, under the chain sprocket for the clutch, and runs down the mounts on down the tube.
It looks like it's been leaking for a while.................I know what you're going to say, "Don't you look over it more often?" Well, I guess not.
It runs good and everything seems "normal", but I just want to know if this is something I can just write off.
Don't feed the bears....
Old 03-18-2010, 04:06 PM
hiker472's Avatar
Default Re: Grease leaking out of bottom of engine
I guess silence on this issue means everything is peachy and I can just write it off as a normal occurrence.
Cool, it's another nice day for a ride!
Old 03-18-2010, 05:56 PM
Dave31's Avatar
Dave31 Dave31 is offline
A little grease leaking out is normal on some engines especially if it's new. It's just grease that they pack into the bearings and when you run it the fuel washes it out. It should stop after a little while.
Old 03-18-2010, 06:09 PM
NEAT TIMES's Avatar
NEAT TIMES NEAT TIMES is offline
fair, what will stop after awhile?? the motor or the grease?!! lol. just messing with you. you two guy`s are my best friend`s, your age`s and size!! ron
PUMP YOUR BRAKES HAVE TO LOVE WINDOWS & THE INTERNET
NEVER BEAT ON IT, GET A BIGGER HAMMER
"A MAN WHO SAY`S IT CANNOT BE DONE SHOULD NOT INTERRUPT A MAN DOING IT"
