Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 03-17-2010, 07:07 PM
RedB66's Avatar
RedB66 RedB66 is offline
Default Electric start for 4 strokes
I remember my neighbor having a lawnmower that had electric start. I would like to attempt a 4 stroke project but I just can't get past the look of having a pull cord on the side of the motor.
Is there a way to have electric start? Is it only on the larger motors? Can one of the commonly seen motorized bike kits (4 stroke) be converted?
MOTORBICYCLING.COM STICKERS
Old 03-17-2010, 08:40 PM
Felton Felton is offline
Default Re: Electric start for 4 strokes
Saw a guy start an outboard motor with a cordless drill once (the pull cord broke). I bet you could rig something of that nature. Better hope your battery doesn't die if you stop.
Old 03-18-2010, 12:05 AM
jared8783's Avatar
jared8783 jared8783 is offline
i wouldnt attempt it unless you have a way of charging as you ride
if ya do figure a way of charging it as you ride let us know
Old 03-18-2010, 12:56 AM
tyrslider's Avatar
An 18 V cordless would start a 50cc many times on a charge. You can mt a pulley on it and carry your ripcord in your pocket (you wind it around the pulley a few times tightly and let'er rip). As long as it starts w/i 2 pulls it's not much hassle but if that's not your motor or you run in to some starting trouble, your screwed.
FireBelly Cycles and MachineWorks (lol)
Motorized Bicycles, Parts, Tools and Accessories for the Real World!
Email Support@FireBellyCycles.com
www.FireBellyCycles.com
http://www.youtube.com/watch?v=-kNGVCnjJVs
Old 05-19-2010, 02:04 AM
hrichmon@gmail.com's Avatar
hrichmon@gmail.com hrichmon@gmail.com is offline
Could you use the friction power from a headlamp to charge it? either way... if it gets figured out, and looks good... i’ll take two! good luck
It’s never too early to beef up your obituary...
Old 05-19-2010, 03:04 AM
jared8783's Avatar
could you elaborate a little more on your suggestion please
are you talking about the bicycle generators, those really tiny things?
i wonder if those would be up to the task of constant 30mph+
i wonder if those even have voltage regulators?
a square is a rectangle but a rectangle is not a square
Old 05-20-2010, 01:29 AM
Jesse002100 Jesse002100 is offline
i have a headlight and brake light with a tiny generator that rides the side of the tire have had it for years before the motor and now 200 miles since the motor it works fine the wheel gets warm but i ride 12 miles to work every nice day it still works. but the lights are 6v so i dont think at 6v it could crank it over at such a low amp. it could maybe act as a battery tender while riding but i dont know if it would be efficient. i use a 12v high speed drill to start my pocket bike it starts in about 3 seconds.
my best idea would be the heavy duty in hub generators they are a constant drag and generate alot more power.
like these many options but a bit pricy considering tearing down your old wheel and having a new one built around the generator and trued.
http://www.peterwhitecycles.com/schmidt.asp
Old 05-20-2010, 02:46 AM
haha... sorry.... I don’t know anything about electricity... I was just thinking... if the problem is to get electric power, and the technology exists to create it from friction on a motorless bicycle .... it seems logical that the power created by a 4 stroke (being far greater than my chicken legs) should be able to power the same thing on greater scale to produce a greater amount of electricity... but then again.... I REALLY do not know anything about the subject... just seemed like something i would be interested in if it comes to be.... good luck guys!
