| 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! |
03-17-2010, 09:19 AM
Ready to freak out!
I installed everything like I'm supposed to. Added correct ratio. What is that switch that goes up and down on the carb? Where should I have it. I peddle with the clutch lever pulled in, and it doesn't start!
I am seriously considering putting this thing in the garbage! Biggest waste of time and money I've ever spent thus far. I would love to be riding the bike that I've been fighting with for the past 3-4 weeks. HELP HELP HELP!
03-17-2010, 10:32 AM
Re: Ready to freak out!
You didn't mention exactly what type of engine and carb you have, so I'll assume it's a Chinese HT.
The 'switch' on the side of the (NT) carb is the choke lever. Up = on, down = off.
Try one starting attempt with the choke on, (the engine will probably fire but not start), then a second attempt with the choke off and it will hopefully start.
The engine won't start, or even turn over, with the clutch pulled in. Pedal up to speed, then release the clutch.
... Steve
03-17-2010, 10:41 AM
thanks! I'm going to give it a try. I think I may have the clutch arm on too tight. I say this because I can still pedal without the handlebar lever pulled in. You're correct, it is that type of motor. Wish me luck
03-17-2010, 10:50 AM
Adjust the clutch so that, when released, the engine turns when you turn the rear wheel and, when pulled in, the wheel turns freely without the engine turning.
Good luck, and let us know how you go, for others that read this thread in the future.
... Steve
03-17-2010, 11:10 AM
The engine isn't taking over. It hasn't fired or anything. I've tried it both ways. What does that screw on the side of the carb do? The one with the spring? Should I be adjusting that? Also, how much "play" should a throttle handle have? I ask this because it doesn't seem like it moves an awful lot. Thanks again! This forum has been my savior thus far. At this point, I don't know what to do
03-17-2010, 11:31 AM
I'll assume that the clutch is working OK now.
The screw on the LHS is the idle speed screw. Nothing to do with fuel/air mixture, it simply lifts the slide when turned clockwise, to increase idle rpm. It will make no difference to starting.
The throttle cable should have about 2-3mm of play, so that the cable isn't pulled as the bars are turned side-to-side.
If you're not sure about your adjustment, remove the air filter and you'll be able to see the slide. It should be almost at the bottom, (position determined by the idle speed screw), when the twist-grip is released. When the twist-grip is turned to full, the slide should be at the top.
If all is OK in that regard, check that the carb is getting fuel. If you undo the float bowl drain screw, you should get a trickle until the bowl's empty. Hold a rag underneath when you do this and make sure the fuel is turned off at the tap.
... Steve
03-18-2010, 01:08 PM
You have fouled the plug by now.....Get another plug or 2 (ngk b6hs) and start out fresh again.....They are boogers to get the hange of starting.....
Life in the Fast Lane......
If your living on the edge , you`re taking up too much space....
03-18-2010, 05:13 PM
I've got the motor running at idle. Of course, when the bike slows down, the engine eventually slows too, until it stops. I have no power in my throttle. I mean, when the engine takes over; I turn my throttle, and I can't get any acceleration. ...Nothing. What should I be looking for, and in what position should my throttle be before the engine starts?
03-18-2010, 05:51 PM
Is the throttle cable hooked up????With the clutch in can you rev. the motor with the throttle????
03-18-2010, 06:52 PM
Give it about 1/2 throttle for starting. It's not too critical.
The plug will be fine if the engine hasn't been run yet. At worst, it might be oily. A wash in fuel will fix that. The B6HS is a good idea, though.
djscrappyd, I econd that advice - if you're using the supplied plug, throw it away and buy an NGKB6HS. (Unless a B6HS was supplied with your kit.)
It will do that if you don't pull the clutch in as you slow down - it's not an automatic.
This was covered in post #6. If he read it, we can be fairly sure that cable is connected correctly.
Now that you have it running, run it until it's warm on a clean plug, then remove the plug and check it's colour. This will give an indication of your fuel/air mix. These kits are notorious for leaking air where the carby mounts to the inlet tube.
Also, adjust your idle screw in while the engine is running until it keeps idling without touching the twist-grip, if you haven't already.
... Steve
| Thread Tools |
| Display Modes |
Linear Mode
