Old 03-14-2010, 05:07 PM
NerpAngel's Avatar
NerpAngel NerpAngel is offline
Default Clutch must be "slipping" right?
This is the problem with my friends bike....
http://www.youtube.com/watch?v=PRMB1M4VgZQ
The small wheel turns fine when the spark plug is out... and this motor is only 10 miles old!
Old 03-16-2010, 03:34 PM
NerpAngel's Avatar
Default Re: Clutch must be "slipping" right?
buuuuuumpp
Old 03-16-2010, 03:51 PM
Ghost0's Avatar
Ghost0 Ghost0 is offline
Yes that is definitely clutch slip. Either your clutch cable is too tight, which I can't tell from the vid or you need to adjust the flower nut.
Design is easy, execution the hard part.
www.sickbikeparts.com
Old 03-16-2010, 04:58 PM
NerpAngel's Avatar
I took the cable out and just tried to walk it forward and it still didn't spin. Also, i've tried like 10 different flower nut spots and nothing has worked
Old 03-16-2010, 05:16 PM
Ghost0's Avatar
Well if the flower nut did not solve your problem then I think the problem is more severe. Like something is really broke and not just out of adjustment. Check in Norm's repair section for a thread on clutch removal and repair. I fear that the large spring in your crank case has broken, of course it could have just loosened up but that is where I would start.
Old 03-16-2010, 05:50 PM
NerpAngel's Avatar
this is weird.. cause i don't know why it can spin half way one way but then stop the other half. I'll check his thread
Old 03-16-2010, 06:13 PM
Dave31's Avatar
Dave31 Dave31 is offline
I am on steam powered service so I could not watch the entire vid, But I did hear something clicking? Do we know where that sound is coming from? Is it motor or from the bike?
Try......... http://motorbicycling.com/f30/extern...ing-13973.html
Old 03-16-2010, 06:14 PM
NerpAngel's Avatar
the clicking could have been just the bike. the first part is when it's in neutral and the bike is the part click clickin'.
Old 03-17-2010, 11:37 AM
NerpAngel's Avatar
Update:...
We realized that when we pull the clutch lever in and out, that plate that sits right below the flower nut doesn't fully move in and out. A section of it stays behind while the rest of the plate moves freely back and forth. Why is this one spot sticking like that? The spring right behind this plate is flat against the plate... I even tried my spring on his bike and it was the same problem..
Old 03-17-2010, 01:52 PM
Ghost0's Avatar
It is very common for the pressure plate not to move away from the clutch pads evenly, just the nature of things. Nothing to worry about. Your problem is that the internal spring is no longer applying enough force to engage the clutch. I still think that either your internal spring is broken or has spun loose. Look at Norms clutch repair and rebuild section and you can see how to remove the clutch and output shaft. This will tell you if this is where the problem is.
