Old 06-23-2008, 02:44 PM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
HS Math Teacher
Default Piston Arm?
Question 1: What is this part called?
Question 2: Mine has about 3 to 5 mm play left to right, is that normal or excessive?
Old 06-23-2008, 02:50 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Piston Arm?
Rod. Piston rod.
Old 06-23-2008, 02:52 PM
MrLarkins's Avatar
HS Math Teacher
is it suppose to be tight, or have some wiggle to it?
Old 06-23-2008, 03:36 PM
misteright1_99's Avatar
The technical term for it is "connecting rod"..
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 06-23-2008, 03:50 PM
Pablo's Avatar
Supposed to move with the piston, but have very mininal side to side movement....what ya mean by "wiggle"?
Old 06-23-2008, 05:15 PM
MrLarkins's Avatar
HS Math Teacher
by wiggle, i mean side to side movement...about 3mm to 5mm
Old 06-23-2008, 05:22 PM
Pablo's Avatar
5mm Sounds like a lot - I don't know what the spec is - PM Norman to check this thread!
Old 06-23-2008, 07:54 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
I have no specs. on these engines but I'm guessing you should be ok. You don't see any metal flakes or metalic particles inside the crankcase do you?
That would be caused by a needle bearing trashing on either the wrist pin or on the crank end of the rod.
what you had outlined in red is the wrist pin end of the connecting rod.
You will have some side to side play on both the wrist pin end and the big end of the rod and as sorry as these engines are made probably some circular twist as well.
It looks like either you have a needle bearing wrist pin or else you pressed out the writ pin bushing.
Are you having a problem or hearing a strange noise with this engine?
norms-iron-works.tripod.com
Old 06-23-2008, 08:07 PM
Pablo's Avatar
I think the problem starts here:
http://motorbicycling.com/f3/80cc-mystery-1508.html
Old 06-23-2008, 08:09 PM
Pablo's Avatar
Here's the video of his beast:
http://www.oskgaming.com/downloads/video.wmv = 2.79MB
