Old 06-22-2008, 09:08 PM
Unsolved Rubix Unsolved Rubix is offline
Default Need help with first build
I just had my truck go out on me and I don't have the financials to fix it. So I decided I would take some of my spare bikes and a 21cc Weed Eater engine to get me some transportation till I work things out on the truck. So I would like to know if anyone had any advice, tips or even some great basic plans that work. I don't have any real machining tools so I am limited there.
and I have just about 2 days to get this built.
Anything would really be appreciated, Thank You.
Old 06-22-2008, 09:17 PM
stude13 stude13 is offline
Default Re: Need help with first build
hi; we will try, but until then, go to search. a hint you may use angle iron fron bed frames at goodwill. and for wheel maybe a skateboard. good luck-- alot of guys with pickups will give a lift if you thumb with a bike-it shows you are trying.
Old 06-22-2008, 09:23 PM
Oh thank you, I may have one of my old ones skateboards around.
I have kinda worked out the idea of building one last year but I just let the year slip by too fast. I do have a spare 6 inch lawn mower wheel but I figured that was too big.
Old 06-22-2008, 09:25 PM
Bikeguy Joe's Avatar
I'm sorry, but two days would be pushing a ground up build unless you are very imaginative.
How about mounting the weedeater so the string head runs on the sidewall of the rear tire? Rig up a throttle mounted to the handlebars and off you go.
Old 06-22-2008, 09:26 PM
...or mount the skateboard whell to the end of the string trimmer and run that on the tire.
Old 06-22-2008, 09:31 PM
I guess that could be done. I would really prefer another method.
Old 06-22-2008, 09:35 PM
...see my second post. ;^)
Old 06-22-2008, 09:44 PM
Yea, I saw that. I am thinking about it trying to see what I can imagine. I was thinking the easiest way to go was gonna be a Friction drive. I am just trying to see what ways I can work that out to work the best.
Old 06-23-2008, 11:17 AM
New day....new start on build.
Old 06-23-2008, 12:52 PM
Ok, I think I may of worked out my basic design. Let me know what you think.
I will have my Engine support built with 2x4 I have cut to fit how I need, I will have some chicken fencing over the Engine to keep it from moving around....I will then run a friction Drive by attaching a bike peg I have to the Engine. I have worked out my Throttle, and Kill switch locations.....So how bad is that?
