Old 06-21-2008, 08:31 PM
Wheel Rush Wheel Rush is offline
Default The who-jigger that came with my engine kit ?
I would have searched this in this forum if I knew what I was searching for, so let me add this after saying that, . . .
They say there are no dumb questions, . . . but there just easier to answer !
And after having said that, could you tell me what the who-jigger is that looks like it will fit where the spark plug
goes? It came with my engine kit, I can only guess it is some kind of compression tool.
It is dark iron, has two sets of threads, one larger than the other and a square nut at the top going down through the interior and is short but about the dia. of a spark plug thread.
Old 06-21-2008, 08:38 PM
paul's Avatar
paul paul is offline
Administrator
Default Re: The who-jigger that came with my engine kit ?
it is the Engine sprocket and Clutch Hub puller tool. put in your tool box incase you need it some day.
Old 06-21-2008, 08:59 PM
I'll do that, .Thanks Cruiser
Old 06-21-2008, 09:00 PM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
HS Math Teacher
is this what your talking about?
Old 06-21-2008, 09:32 PM
Dave31's Avatar
Dave31 Dave31 is offline
Yes Mr. Larkins, that is it.
Old 06-21-2008, 09:36 PM
Yep ! Thats the little grubber ! I'll bet there's some tech. data on its use somewhere now that you mentioned it.
Old 06-21-2008, 09:39 PM
Dave31's Avatar
Yes of course, I know Norman did it somewhere. I think I might have posted a youtube video on how to use I think?
Old 06-21-2008, 09:46 PM
Dave31's Avatar
Here it is, listed as " Bicycle engine kit gear removal"
http://motorbicycling.com/f15/youtub...deos-1325.html
I need more time to find Norman post
Hmmm....I could not find Norman using the puller...sorry..
Old 06-21-2008, 10:52 PM
MrLarkins's Avatar
HS Math Teacher
ok, so is there suppose to be any 'wiggle' or 'play' in the gear of the clutch area? or is it suppose to be nice and tight (no play), cause mine wiggles
Old 06-22-2008, 07:24 AM
Bikeguy Joe's Avatar
Do you mean the big gear or the small gear? With the clutch engaged or disengaged? Does it wobble like it's not bolted on right, or wiggle by touching it?
