Old 06-21-2008, 05:28 PM
Tj Bunch Tj Bunch is offline
Default Cat Converters On a Bike?
Is cali Really that anal about the emissions on a bike engine to make me use a converter? Man thats crap and how does that affect the performance?
Old 06-21-2008, 09:59 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: Cat Converters On a Bike?
I don't know about Ca making use a cat....I know some with a cat and they say they can't notice a difference... Hopefully they can give a little more info
Old 06-22-2008, 01:33 AM
No I bid on one and the guy cancelled me b/c he said he could not ship to cali. And refered me to another that has a cat.
Old 06-22-2008, 06:38 AM
nitroscope8 nitroscope8 is offline
We have one on a 48cc. It's VERY quiet and no noticeable drop in performance. The drawbacks are that it gets VERY, VERY hot. Hot enough to give you sunburn on your leg. You must remember that a cat will burn any hydrocarbons in the exhaust...this means oil, fuel, etc. Less oil in the mix is better for the cat and it won't heat up as much.
48cc Giant. 50T, 26" wheels, catalytic converter-Built for Younger brother.
66cc Trek 800. 50T, 26" wheels, SBP tuned pipe. Top speed: now unknown.
Old 06-22-2008, 01:57 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
I would like to see what is inside of the so call cat exhausts. From my experience on the oil industry running a cat on heavy/big industrial engines oil comming out in the exhaust spells the end of a $5000.00 cat comverter or an expensive engine over haul to get it back to meeting the emmissions. A engine with a leaking intake guide seal will cause a cat to plug or stop working so how can a cat on a 2 stroke work or work for very long? I think someone is blowing smoke.
norms-iron-works.tripod.com
Old 06-22-2008, 05:25 PM
Not really Norman! I understand where you are coming from. VW cats run between 400 and a grand. These are 30 bux. I looked inside and the catalyst has large pores. This doesn't scrub the exhaust as well as a cat with many, smaller pores. Most 2 strokes made today have cats on them...such as yard equipment. These require a leaner fuel/oil ratio. Our Echo blower takes 93 octane 50:1 premix and has a catalyst.
These bike engines for 08 have a sticker saying they need 40:1 mix.
Old 06-22-2008, 09:05 PM
Skyliner70cc Skyliner70cc is offline
Banned
I'm with norm, oil in exhaust is the death of a cat.
Old 06-23-2008, 12:22 AM
For a normal CAR or TRUCK cat, yes. How is this bad for a 2 stroke cat if it is designed to work for a 2 stroke engine? Environmental Lab Testing of Two-stroke Engines Confirms Over 80% Reduction of HC and CO Harmful Emissions With Advanced Fuel Carburetor and Cat Converter | Business Wire | Find Articles at BNET
Old 06-23-2008, 01:12 AM
Don't cats just run Hotter to Reburn anything that pases the norman Burn chamber? I mean like a chevy cat has platinum in a heneycomb that supeheats and reburns the exaust/
I just can't see how a 2 stroke one works.
Old 06-23-2008, 08:48 PM
Norman's Avatar
When we got oil on our cats they would do a nueclar melt down. We had precat temp and postcat temp probs and they would shut down the engine if it went over 1200 on the post temp. seems like they had to get to 600 degess f to start working. I know the crankcase vent bypassed the cats so the vapors from the crankcase didn't go through the cat.
The emissions carp on these engine would drive you nuts when they didn't work right. They are tested every month so they have to work and that can be no fun at times.
