Old 06-20-2008, 08:34 PM
Howitt Howitt is offline
Default full throttle?
Is it damaging to ride a motorized bike with an 80cc happy time motor at full throttle for a long time? I will be using my motorized bike to travel 24km to work and would like to try and get there as fast as I can.
Old 06-21-2008, 01:30 AM
Dave31's Avatar
Dave31 Dave31 is online now
Default Re: full throttle?
I have never held it wide open for a very long time. I usually will feather the throttle every now and then. I'm not sure if holding it wide open would hurt it, but the way these motors are made I would not.
Maybe you might want to change the sprocket to get more speed?
Old 06-21-2008, 05:28 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
I'm not sure about wide open all the time because frankly the bike scares **** out of me wide open. It isn't blowing the engine that scares me it's hitting that big pot hole at thirty miles an hour that does it for me.
Old 06-21-2008, 06:11 AM
nitroscope8 nitroscope8 is offline
I've been riding full throttle for a while. I see no harm. Just back off when the vibration barrier comes up.
48cc Giant. 50T, 26" wheels, catalytic converter-Built for Younger brother.
66cc Trek 800. 50T, 26" wheels, SBP tuned pipe. Top speed: now unknown.
Old 06-21-2008, 06:54 AM
sisdavid sisdavid is offline
I drove to the hardware store wide open the entire time about 20 minutes. Was really fun. I would use about 5 ounces of good quality oil semisinthetic.
Old 06-21-2008, 09:03 AM
Pablo's Avatar
Pablo Pablo is offline
Well balanced, well breathing 2-stroke gas ICE's do best in their powerband. Sometimes that isn't always full throttle.
Tell me more about the bike. But from the start I would say you need more power to the ground and merely suggest the following:
1) General tune, right oil mix, good spark plug and wire.
2) Port and polish the intake and exhaust.
3) Install an expansion chamber.
4) Get a shifter kit and take advantage of gears if you can.
I can do 40 mph in 4th gear and have yet to explore 5th and 6th.
Old 06-21-2008, 03:59 PM
Skyliner70cc Skyliner70cc is offline
Banned
My reply:
New engine not broken in: Holding the same throttle setting and/or load on engine will not properly break in your engine. A new engine needs a lot of variability in engine rpm and engine load. WOT and heavy loads and/or high rpm for short periods of time are essential.
Broken in engine: WOT operation wtihout overrevving engine is just fine provided mixture is not too lean. When I lived at high altitude, WOT was I rode most of the time.
Old 06-21-2008, 04:47 PM
Pablo's Avatar
Good points Skyliner
Old 06-21-2008, 07:27 PM
larger sprocket gives more speed? interesting.
Old 06-21-2008, 07:28 PM
what mixture ratio would you suggest I use for WOT for 24km in toronto?
