Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 02-20-2010, 03:44 PM
bobw bobw is offline
Default spookytooth/schwinn cruiser engine mounting
I am a real new guy and recieved my kit from ST. Took it out of the box and dry fitted it to the schwinn cruiser. The mounts seem to be a long way from my tubes. I need help on this . Thanks bob
Old 02-20-2010, 06:29 PM
Nougat Nougat is offline
Default Re: spookytooth/schwinn cruiser engine mounting
The rear mount should be flush up to the seat tube. Then you have to fabricate something to go on the front mount to the down tube.
The way I did it was to get a 4" x 12" x 1/4" hunk of metal from Farm & Fleet. I cut that down to about 4" x 4". Drilled a couple holes to attach it to the front mount on the engine, and a couple of other holes, just a little wider apart, so I could use a muffler clamp around the down tube.
There are a couple of places out there selling mount kits that are similar to this construction, for ten or fifteen bucks, if you don't feel like cutting and drilling - although I don't think the metal plate will be quite as thick.
Old 02-20-2010, 09:56 PM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
Doood... If you look through all the posts here, YOU WILL FIND A WAY TO DO IT!
Old 02-21-2010, 01:31 AM
I have started looking at the different posts and there are alot of options. Nougat, I was not sure which side of the motor got the extension ,thanks. Right now I have it snugged up to the front bar, will change. bob
Old 02-21-2010, 02:22 AM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
here's how i did mine: http://motorbicycling.com/f26/how-i-...tor-13429.html
