Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 02-17-2010, 06:59 PM
recyclingproperty recyclingproperty is offline
Default Help
Hey, I'm looking to mount a Ryobi weed wacker motor to the back of my bike. Not sure the best way to go about it. I wanted to do belt drive rather than chain, but needed help in terms of figuring out how to best attach pulleys to the wheel and drive shaft as well as how to best dissengage the belt. Thanks!
Old 02-17-2010, 08:37 PM
diceman2004's Avatar
diceman2004 diceman2004 is offline
Default Re: Help
my best advice is , read .
theres lots and lots of info and ideas here .
do a forum search on weedwacker and look at what others have done , there are some really nice weedwacker bike setups .
Old 02-18-2010, 05:00 AM
Bikeguy Joe's Avatar
Default Re: Help
Check out the DIY forum here for lots of help and advice.
Old 02-18-2010, 11:17 AM
professor's Avatar
professor professor is offline
Default Re: Help
By far the easiest thing for a wacker install is some form of friction drive, where a rotating drum against the tire propells you. Even that, usually requires some machining work.
Easier would be to buy a kit where all the engineering is done already. Which is the reason you see very home- built friction drives.
The type of drive system you are thinking about with belt or chain is something I have not seen during the hundreds of hours I have been on the motor bike forums, it is just very difficult and time consuming to do.
Maybe someone somewhere has done it- I wouldn't go that route with that engine.
Old 02-18-2010, 07:31 PM
motor_head's Avatar
motor_head motor_head is offline
Default Re: Help
if you can figure out a way to put a pulley on the motor (needs a shaft with one round end and a square end and a bearing support for the round end or the square bit will snap off)then just weld another rim to the regular back rim and use that as a big pulley
Old 02-19-2010, 04:23 AM
Default Re: Help
You could mount up a chainsaw and just turn it around and use the clutch bell to drive right on the tire....I've seen it done.
Uber simple.
