Old 02-07-2010, 10:58 PM
Techbiker Techbiker is offline
Default CNS Carb or NT Jets?
I am debating about whether I should go with a new CNS carburetor or with a couple different jets for my old style NT carburetor. My 70cc Dax engine is running very rich and my plugs foul right away. It usually 4 strokes and only 2 strokes occasionally when I am going up a very steep hill. I also need to get an offset intake manifold since my stock one hits my seat tube. I was wondering if it would be a better idea in the long run to just get a CNS carb. I am guessing that I will spend $25-$30 on an offset intake and a couple jets including shipping while the CNS carb is $50+ shipping from Spookytooth. Will the CNS carb allow me to lean out the engine a bit and is it worth the extra $25? It also comes with new fuel line and throttle line so I would take that into account too... I am only wondering this because if I end up having to rejet the CNS carburetor anyway with a smaller jet or something, I might as well just get some jets for my old carburetor.
Thanks
Old 02-07-2010, 11:50 PM
turkman's Avatar
turkman turkman is offline
Default Re: CNS Carb or NT Jets?
Hey now I don't know what you should but here's what I did and what happened,44 tooth rear sprocket nt carb 29 mph,plenty of torqe on hills ,changed sprocket to 36 tooth 32-34 mph ,tried re jetting and ? didn't seem to make a diff , put on a CNS stock manifold 35 mph no four stroking , made a large id manifold 39 mph BANG!.I wonder if your motor is broke in it took about 4 gal. to get mine to smooth out that all I got on this , good luck Later Bob
Old 02-08-2010, 12:10 AM
I've put about 150 miles on the engine so it might not be broken in yet, although it does seem to be picking up more power. I guess that you recommend just getting the CNS carb. $50 isn't too much and it seems to come with quite a bit of accessories. I'm running a 40 tooth sprocket by the way.
Thanks
Old 02-08-2010, 12:43 AM
stv1jzgte stv1jzgte is offline
Firstly if you are 4 strokeing with an nt yes your way to rich and should fix that first and see how it goes
. Bolting on the cns will cause it to constantly 4 stroke as the jet is alot bigger than the nt yeh it process more air but more fuel also.
Rejet you nt smaller you should never be 4 stroking
You can just but a smaller drill bit, solder your jet up then drill smaller .60 - .65 should do it
Old 02-08-2010, 10:49 PM
421SmQQthie 421SmQQthie is offline
i just ordered a cns carb for mine because the old style carbs are designed for a 49cc motor and never should have been sold for 66cc or 80cc the cns carb has a bigger everything but yea mabee your not mixing your gas proper is it is 4 stroking the only reason i ordered my carb is because at top rpm's the motor seems to be running out of gas or hitting a govner i think this new one will help[ but i will know soon just ordeered it tonight.
Old 02-08-2010, 10:50 PM
http://motorbicycling.com/f4/carbora...ent-15174.html
Old 02-08-2010, 11:10 PM
I talked with Spookytooth and they just recommended going with the CNS carb since it includes a fuel/air mixture screw and since it is more precise. They said that the fuel/air mixture should work with a stock 70cc engine but that it will need to be adjusted. I'm going to install the new carburetor this weekend so I will get back and let you guys know what happens. Hopefully I'll be able to get the mixture right.
Also, I plan to grind out my muffler opening to improve air flow. I don't want to grind out the inlet/ outlet on the cylinder right now since I don't want to take the engine apart. Hopefully this will allow the engine to run better. Thanks for the replies.
Does anyone have any experience with adjusting the CNS carburetor?
Old 02-09-2010, 01:09 AM
Originally Posted by flybytaco View Post
YouTube - 926_0420.MOV
std nt style carb guys on a 66 cc
Not to get into a pissing match but you dont seriously think that a 12mm nt carb is going to be better than a 16mm with air/fuel adjustment do you
Old 02-09-2010, 03:37 AM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
before you start spending money, have you tried the basics? like moving the needle clip up? what mixture are you running? you say you've got 150 miles on the engine, have you leaned out your mixture or are you still running the same fuel/oil ratio as your first tank? is your air filter clogged with oil? have you smoothed out the casting flash in the intake manifold? you can do a little port matching to it with a dremel, too.
there's a lot of little basic things that you can do for free before you start throwing money at your problems.
i'd hate to read a thread from you saying how the new carb sucks and it's a waste of money...
Old 02-09-2010, 10:16 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Yep... I've had really good luck with simply jetting & cleaning up the stock carbs!
I can't believe how many times I've read about guys who put every high $$$ part they can find on their bike, & then they can't get it to run right!?!?!
