Old 02-04-2010, 09:59 PM
kornbread's Avatar
kornbread kornbread is offline
Default raw engine- kill switch bad?
my new 66cc raw motor has finally been installed but why don't my kill switch work?
Old 02-07-2010, 07:34 AM
Bikeguy Joe's Avatar
Default Re: raw engine- kill switch bad?
Because they are notoriously bad pieces of junk. You can take them apart and make them work, or just buy a new quality one. Or, omit it completely.
Old 02-07-2010, 12:22 PM
Nougat Nougat is offline
Mine, also a RAW, for what that's worth, will kill the bike immediately sometimes, and other times after many seconds of holding it. I have mine wired to white and frame, and from what I've seen around here, it's behaving normally.
Old 02-07-2010, 12:35 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
The kill buttons on most every kit out there are 'hit or miss'.
Whenever someone asks why their bike isn't running, most people first suggest disconnecting the kill button!
I've found that the best way to wire them is to attach one wire to the blues & the other to the blacks, & cap off the white.
Old 02-08-2010, 10:08 PM
daledoo daledoo is offline
Try grounding it to the motor mount, a bigger screw than probably it was set up for. If it came with a smaller eyelit, cut it off, strip it and install a bigger eyelit to the motor mount, and try it.
