Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 06-17-2008, 11:26 AM
geerhed geerhed is offline
Default what size rear sprocket too small for 50 cc Titan engine?
for a 185 lb rider on flat surface with 26"tire, what is the smallest rear sprocket possible for a 50 cc titan engine before the engines torque is not enough to sustain top speed? Is 27T too small? what would you estimate top speed with a 27T sprocket?
Old 06-17-2008, 12:08 PM
FileStyle's Avatar
Default Re: what size rear sprocket too small for 50 cc Titan engine?
I have a 2 stroke 70 cc with no modifications , 26" tires , and a 36t sprocket and run about 30 to 35 mph. little slow on the takeoff , I have to help pedal a little but on the top end I 'am moving pretty fast for a bicycle! I imagine if you installed a 27t sprocket , just a guesstimate maybe 40 to 45 mph , which should be plenty fast! the real question would be after successfully adapting a 27t , how am I going to stop?
FileStyleCycles
