Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 01-30-2010, 12:23 AM
doubledice's Avatar
doubledice doubledice is offline
Default slight cut outs at full speed?
Hey guys i got an 80cc slant head motor from zoombicycles and it works great but when im going full throttle at the straights it cuts out alil bit and it bugs me. i have the baffle taken out on my exhaust so im thinkin since there is less restriction in the exhaust its flowing faster and the engine is getting starved of fuel and it needs better/more fuel flow to the cylinder cuz thats what it feels like? what do you think???
Old 01-30-2010, 12:50 AM
PaulFlorida's Avatar
PaulFlorida PaulFlorida is offline
Default Re: slight cut outs at full speed?
That happened to me, but worse, with the stock motor. I ported first, and it still did it. I bored the carb, it did it worse. I put a SBP pipe on it, it helped a bunch, just now and then, but every ride. I added the "racing carb" and the C.E. billet intake, and it screams WFO all day long. IMHO, these motors are extremely restricted on port timing, intake, and exhaust.
Old 01-30-2010, 01:09 AM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
some simple things that can you can do to try to stop it...
what plug are you using? upgrading to an NGK will help. i run a B7HS, and have used the B6HS as well. the 7 is a colder heat range, and it works for me in California, but my motor's got some performance tweaks.
get a new plug wire, too, if you haven't already. i use a copper core 7mm wire.
something as simple as a weak spark can make it sputter at full throttle.
match the intake manifold as much as you can, you can't get it perfect, because there's not enough metal, but you can open it up. also, grind away the casting flash on the inside of it. you don't want a mirror finish, because the fuel needs turbulence to atomize properly, but getting rid of "obstacles" like the bad casting marks helps.
what's your needle setting at? mine's second notch down. playing with that will affect fuel flow, just keep an eye on your plug color so it's not too lean, or too rich.
fuel mixture has an affect on it too.
and make sure your air fliter's clean. it'll clog up with oil and won't breathe.
de-carbonizing the top of your piston helps, too. just pull the head, put the piston at Top Dead Center (TDC) and spray it with some carb cleaner. i use a toothbrush and scrub it a bit. some stuck chunks can be scraped off with a knife, or a scotchbrite pad.
DO NOT use sandpaper, steel wool, or any other abrasive that can get into the cylinder, and make sure the chunks you clean off don't get in there, either.
scratched cylinder walls will be waaay worse than a little four stroking...
one last thing, did it sputter when you had the baffle on?
Old 01-30-2010, 02:07 AM
Goat Herder's Avatar
Gutter Rider
Float bowl not catching up with demand is possible. A slight adjustment of the float? Just thinking out load here.
Old 01-30-2010, 09:39 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
what oil to gas mixture you running ?
norms-iron-works.tripod.com
Old 01-30-2010, 11:58 AM
doubledice's Avatar
It was worse with the baffle on it. I like to run about a 20:1 fuel ratio witch works better for me but i used some friends 2 stroke witch looks around a 16:1 im just goin off color on that tho. How do you change the wire out i always see guys on here with that
Old 01-30-2010, 12:59 PM
Outrunner's Avatar
Outrunner Outrunner is offline
Exclamation Re: slight cut outs at full speed?
I strongly suggest using Amsoil Synthetic or Opti 2 Semi-synthetic (True Value hdwre) and
mix the Amsoil at 3.5 ozs per gal. which is about 40:1. Opti-2 packets are prepackaged for
1 gal. at 73:1 ratio. Don't worry about these ratios, they are tried and proven to work fine.
AS far as the plug wire, it is the spark plug boot that typically gives problems. Make sure that the wire makes a good connection inside the plug boot. You could also buy a high quality wire from Napa with a new plug boot. Your 20:1 oil ratio is too thick for top performance for sure!
Change is inevitable and progress is OPTIONAL!
Old 02-01-2010, 11:25 PM
doubledice's Avatar
I believe i have figured out my problem, I took off my spark plug just to take a look at it and the tip of the plug where the spark jumps was moving up and down all i could say to the guys in shop was "bet you have never seen this before!" my motor is running with no gap on my plug idk how but it is. iv been looking at a spark plug on spooky tooth cycles it has 3 prongs on it instead of just one, what do you think???
Old 03-11-2010, 12:59 PM
Traveller Traveller is offline
I have a similar problem with my PK 80cc.
The engine loses power dramatically at full throttle (~30-35mph), but only after traveling for about 1mi at that speed/rpm. If I pull the clutch in and let the motor rest for a few minutes I can get it to about 30-35, but have the same problem a mile down the road. The gap on my spark plug is 35 and running 23 to 1.
One thing I realized is that if I keep the speed limited to 15-20mph (36T) then it doesn't bog down at all.
I checked my spark plug when I came home and it was 25. Is it normal for the gap to reduce when you rev the engine high for long periods of time?
Could a clogged exhaust with oil be causing it?
Old 03-11-2010, 06:00 PM
kla63's Avatar
kla63 kla63 is offline
i backed off on my fuel cock just alittle that back off on my engine bogging !!! its work on many of my motors gas bicycle motors Home
