Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Wheels, Brakes and Suspension
Wheels, Brakes and Suspension Keep your motorized bicycle on the road with suspensions, rims, tires and disk, drum and caliper brakes
Old 01-29-2010, 04:06 PM
Astroy Astroy is offline
Default New to motorbike world--Help with brakes!
Hi I'm going to be posting from time to time for advice and questions. I've never built a motorbike before so thank you before hand for any help. I have a newer model schwinn stingray-krate frame and I have a question about the braking system. My goal is to get an 80cc engine to fit on it and I'm most likely going cut the frame and mod it a bit. My question is, what should I do about the braking system? I mean is there any alternative more improved parts for motorbikes to make it safer when going higher speeds and decelerating?
Old 01-30-2010, 12:23 PM
Russell's Avatar
Russell Russell is offline
Default Re: New to motorbike world--Help with brakes!
Try a search on krate. If you search on stingray more than likley you'll get mostly OCC info.
However I have been riding for about a year with standard front and rear brakes(non-coaster) and not any problems.
Old 01-30-2010, 12:43 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
you can buy a 20" front drum brake wheel on ebay, but they're spendy. and a rear coaster brake will work fine. i've got that set up on my 24" bike, and it's got all the stopping power i need.
Old 01-30-2010, 06:14 PM
marts1 marts1 is offline
Any braking system I've used would lock the wheels if squeezed hard enough. Not sure if you can improve on that other then more rubber on the road or less air pressure in the tires.
Old 01-30-2010, 07:58 PM
Thanks a lot everyone I'll look up what you've all suggested so far. My only concern with my bike is it's got no gears, and one simple braking method, I hold back on my pedals and my back tire brakes. So I should definitely look into a front brake.
Old 01-30-2010, 11:15 PM
Yeppers, that front brake will at least double your stopping power and triple your odds of going head over heels. j/k
