Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 01-24-2010, 06:39 PM
Kevron99's Avatar
Kevron99 Kevron99 is offline
Default Wide Engine Mount Spacer
Guys I need a 2 inch wide mount spacer. Does anyone know what vendor sells this? I need a wider mount to space into my front mounts. I have check all sites that I know off including e-bay they all measured to 1.5 inches only. Desparately needs help. Any suggestion is highly appreciated. Thanks
Old 01-24-2010, 08:12 PM
PaulFlorida's Avatar
PaulFlorida PaulFlorida is offline
Default Re: Wide Engine Mount Spacer
for 35 bucks, Jim at creative engineering had a fantastic mount set up. He's on the side bar to the left
Old 01-24-2010, 08:32 PM
Kevron99's Avatar
I know Jim' mount. But I am using it for mounting an engine with a jack shaft.
Old 01-24-2010, 08:34 PM
Salty Gator's Avatar
Salty Gator Salty Gator is offline
I'm planning a road trip first week of Feb. for the exact mount you speak of Paul....I'm 2.5 hours north of Jim and figured I'd pay less for gas than I would shipping since I'm also going to be purchasing his sprocket and adapter as well as his intake....I spoke with Jim on the phone this week and he said " come on down ! ".....his mounts are the bomb !
Salty
Old 01-24-2010, 08:36 PM
Call Jim and see what he says about his mount working with a jackshaft.....there's bound to be a way to utilize it .....
Good luck,
Salty
Old 01-24-2010, 08:40 PM
Gas Bike sells a universal mount that will fit 99% of the frames out there ....I bought one myself and it works just fine.....www.gasbike.net
Salty
Old 01-24-2010, 08:41 PM
Kevron99's Avatar
Yeah...Thanks Salty. But all I need is a spacer since there was an inch and a half gap between my motor and my custom front mount from Ridleys.
Old 01-24-2010, 08:54 PM
You're welcome Kev and sorry I can't be of more help....Have you considered a machine shop fabricating one for you ?.....a small piece such as that shouldn't be too pricey......
Salty
Old 01-24-2010, 09:06 PM
Cabinfever1977's Avatar
im sure you can make one yourself.
Old 01-24-2010, 10:56 PM
2door's Avatar
2door 2door is offline
Kev,
Do you mean 'wide' or 'thick'? I consider the width to be the distance from side to side. The bolt centers are only about 1 5/8" inches so you couldn't open up the saddle, semi-circular portion to 2". If you mean the thickness, from the engine case to the seat tube center, then fabricating a 1/2" spacer shouldn't be difficult. A piece of scrap aluminum should be easy to find or even your local Ace hardware has 1/4" aluminum that you could stack to give you the extra 1/2" you need.
