Old 01-13-2010, 06:28 PM
townem townem is offline
Default Hello from Sydney Australia
First time user and new motor owner
The state where I live is very restictive on motorised bikes. Limit is 49cc & 200watts. Hello . . . totally useless with all our hills - so my bike is a Rock Solid Engines 68cc on an old 26" mountain bike. I am looking to change this to a cruiser style bike which are expensive and limited in choice here. What I really want is to have a rear motor sprocket attached to the rear hub and not on the spokes.
Old 01-13-2010, 06:32 PM
EnFlaMEd EnFlaMEd is offline
Default Re: Hello from Sydney Australia
Welcome from Adelaide. I wish we could get cheap cruisers in Aus it sucks.
Old 01-13-2010, 07:00 PM
Have been looking at the GT1 cruiser for around A$400 as it has the rear sprocket attached to the hub already - but not much else. Also wanting to try to quiet down the exhaust a little to draw less unwanted attention, but try not to limit power too much.
Old 01-13-2010, 08:08 PM
Dave31's Avatar
Dave31 Dave31 is offline
Smile Re: Hello from Sydney Australia
Welcome townem, glad you joined us.
Old 01-13-2010, 09:31 PM
wildemere wildemere is offline
Your options are a the disc hub method, The HD hub available locally from MBB imports and others or the SBP shifter kit.
I actually use all three and think the HD hub is the easiest solution, It also comes with a band brake. The disc hub will require an adapter between the hub and sprocket. I made mine but they are available in America from Kings. The last option is the best but most costly and labour intensive of the three options.
Old 01-13-2010, 09:41 PM
But the shift kit is super awesome!
Old 01-13-2010, 09:43 PM
Thanks for the info. I have just seen the shift kit on a US site. It does not seem an easy and quick fit plus as you said it isnt cheap. I will look at the HD Hub - I assume that is the one that is on the GT1 cruiser on the MBB Imports site. I have also found a cruiser bike on the Gasman Bikes site for A$300 with the sprocket fitted as well.
Old 01-13-2010, 10:08 PM
That gasman bike looks nice, it has a disc brake and suspension forks.
I would inspect the quality before buying then fully service before riding though.
The GT1 is also cool, made for motorizing.
Old 01-13-2010, 10:29 PM
Spoken to both distributers. The GT1 looks to be a better build. The crank set is better, it is an HD hub while the gasman is only a sprocket fit. But the gasman has more options. But I think I will go for the GT1
Old 01-25-2010, 06:10 PM
brad reeves brad reeves is offline
rock solid makem in different sizes
