Re: 4 cycle kits
I don't think you could really go wrong with either. I have no direct experience with the EZM, but everything I have heard is positive.
The Honda/Grubee is the devil I know...and I like mine (mine is a Stage II, but internally, they seem to be the same). It's going to sound like I am knocking the Honda/Grubee, but I am not- I just have over 2 years on this setup and know its ins and outs.
I have not had this problem myself, but some people have had gear teeth chewed up on the clutch bell. Not me, mine are like new, but it has been an issue for a couple of people. Also, the Honda is set up with a governor and a throttle that does not lend itsef to twist throttle use without modification....but it's been done a lot, so there are plenty of solutions. There is also the ongoing saga of whether to run it wet or dry. I ran it wet- slipped a lot, then I ran it with grease- quiet, but....we can do better....so thinking about going back to wet, but with changes. Then there is the noise- some gearbozes are louder than others, my gears sing at times- not bad.
Good luck!
