Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Heads and Cylinders
Heads and Cylinders All about your porting, compression, rings, cylinder and piston modifications to your bicycle engine
Old 01-06-2010, 08:34 PM
steef steef is offline
Default Head Gasket ??
I think I blew the head gasket on my motor.The motor turns over fairly easy with the clutch engaged.
It looks like it's leaking gas under the head gasket, and the *#@^ thing won't crank.
Is it better to buy a new gasket or just make one, and what about torquing the head, do I need any special tools?
Old 01-06-2010, 09:04 PM
Evan's Avatar
Evan Evan is offline
Default Re: Head Gasket ??
The info that I have says torque to 12-15 foot pounds in an 'X' pattern. And I would buy a gasket for it rather than make one because the ones for heads are partially metal rather than all asbestos. I don't claim to be an expert so before you do anything see what everyone else has to say
Old 01-06-2010, 09:05 PM
Riding Rich Riding Rich is offline
Banned
You need a torque wrench.
Should anyway.
You could make one out of copper plate.
Prolly should change the base gasket.
My 1 motor acts the same way when the base gasket is gone.
Old 01-06-2010, 11:03 PM
stv1jzgte stv1jzgte is offline
Your the torque wrench! all the bolts are 10mm so never use anything bigger than a 1/4 ratchet or a 10mm spanner and dont jump on em
Old 01-07-2010, 04:18 AM
Prasinos's Avatar
Prasinos Prasinos is offline
If the gasket looks OK just heat it up with a blowtorch and let it air cool, then reassemble it, if the gasket is not cracked then its not the problem. A little leakage out of the head is almost normal with these things.
If you really want to get rid of the leakage you should sand the mating surfaces smooth on a piece of glass covered in sandpaper.
BTW i wouldn't advise buying a new base gasket, just make one out of a roll of gasket paper. The whole roll will cost you about the same as one gasket will, and you can use it for all your gasket needs.
-Phil in CT
