Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make you run smooth and trouble free
Old 01-05-2010, 06:55 PM
bradentonmotorbikes bradentonmotorbikes is offline
Default 40 Tooth Sproket Vs. 36 Tooth
Im debating between purchasing a 40T or 36T for my bike.
Can anyone tell me the speed increase for each sprocket?
Were maxing like 29mph with the Stock 44T.
I live in Florida so no hills, and Id still like to have pretty good Pickup, so which should I chose?
Thanks
Old 01-05-2010, 08:51 PM
Riding Rich Riding Rich is offline
Default Re: 40 Tooth Sproket Vs. 36 Tooth
A 36 is great if you have an 80.
Not too bad with a 48.
Just depends on how much you want to peddle at takeoff.
You will loose a little lower end but gain tons of top end.
Old 01-05-2010, 09:01 PM
Bucketh12 Bucketh12 is offline
I have been using the stock 44t and have attained a top speed of ~30mph. I bought a 36t sprocket from spookytoothcycles for $25 and I plan on putting it on this weekend. I'll let you know how it fares as far as speed and acceleration are concerned.
Old 01-05-2010, 09:22 PM
I can 40 to 45mph with a 36T and a modded engine
Old 01-05-2010, 09:35 PM
spit_fire's Avatar
spit_fire spit_fire is offline
do you still have pick up with the 36t or do you have to peddle everytime you go, i have a 50 tooth for the winter and it only goes about 42km/h but it can push me threw any snow and i dont peddle to take of but i want to switch to a 36 in the spring once weather permits
Old 01-05-2010, 10:38 PM
Cannonfish's Avatar
Cannonfish Cannonfish is offline
There were several posts on this website in months past that estimated somewhere around a 1 mph increase in speed for every 1 tooth decrease in sprocket size.
This estimate seemed about right to me when I switched from a 36T sprocket to a 40T - I lost somewhere around 4 mph on my top end, but then I didn't have to pedal quite so much to get moving from a stop.
My top speeds on both these sprockets were way lower than a lot of people have reported - according to my Cateye speedometer, I maxed out at about 30 mph with the 36T and about 25 mph with the 40T. And that was getting up to uncomfortably high RPMs.
Old 01-06-2010, 06:25 AM
BarelyAWake's Avatar
Thank you Cannonfish for your honest review
Despite incessant claims to the contrary - anything beyond 35mph is a simple matter of the exponential torque demand caused by wind resistance - and NO sprocket in the world is gonna add depth of stroke to your HT.
Changing sprocket sizes will alter your acceleration by changing where the applied powerband is - but the only things that will actually make you get a higher top speed is more power/reduced wind resistance/drag reduction.
edit: unless ofc yer limiting yerself by redlining at 20mph... which is a completely different story - but at least yer 0-20 will be amazing lol
Old 01-06-2010, 08:52 AM
I have calculated the rpm required to hit the speeds i claim.
Definatly your motor needs the ability to turn 8000 rpm to hit 40 MPH with a 36T.
Yes you can get 8000 rpm outta a HT.
If the whole setup is correctly applied.
In the stock world your gonna be lucky to go 30mph.
Now granted if you sacrifice some of the low end and peddle more your speed will increase in the top end.
If you build the motor up strong to take high revs.
Port / and Pipe and gear correctly.
You can go very fast.
For every motor of a given HP there is a Torque / HP Curve.
Essentially once the curve peaks highest torque the torque then drops off down the curve.
So if you gear right and your power band is set right you get up to say 30 MPH fairly Quickly.
After that torque and power drop off but you allready going 30 so you dont need as much.
You need the motor to keep reving higher.
There is a fellow in Erie i ride with.
MOTORBIKEMIKE45
Hes on the other forum.
He has a speedo and when we ride he says we goin 27MPH before i even hit half throttle.
I ride in traffic 45 mph Zone and keep up.
In Erie 25mph means 35mph and i ride that all day long.
Now honestly most will never see 35MPh but the person that dose every last thing possable to there motor and dose it correctly.
Will see higher speeds.
Old 01-06-2010, 09:01 AM
While I agree with some of what you've said - the above quote is dead wrong. As your speed increases (in the real world vs "calculations") you've got wind and mechanical drag to contend with and that's an exponential equation.
or;
Originally Posted by wiki
Note that the power needed to push an object through a fluid increases as the cube of the velocity. A car cruising on a highway at 50 mph (80 km/h) may require only 10 horsepower (7.5 kW) to overcome air drag, but that same car at 100 mph (160 km/h) requires 80 hp (60 kW). With a doubling of speed the drag (force) quadruples per the formula. Exerting four times the force over a fixed distance produces four times as much work.
http://en.wikipedia.org/wiki/Drag_(physics)
THIS above all things is what limits the speed of these lil Chinese motors - modded or otherwise and is why I view all unsubstantiated claims with... skepticism (bicycle speedometers being famed for inaccuracy and incorrect settings - only GPS or a pace car is believable).
This is an example of a substantiated claim;
http://motorbicycling.com/f13/hybrid...tml#post140947
YouTube - 2 stroke hybrid puch motorized bicycle
Old 01-06-2010, 09:30 AM
Yes i do agree with you on that 100 percent.
A person on a bicycle has about as much or more wind resistance as a Tractor Trailer.
Check Out
Thunder Products - Performance carburetor and clutching for snowmobiles, motorcycles and ATVs.
Affordable Accurate tacometer that reads the spark.
No way to cheat it and make it read higher or lower.
This spring i'll get one and see what kinda RPM i really get.
With accurate RPM it is possible to calculate accurate speeds.
I'd really like to know my true speed.
Too much snow here now to even attempt it.
MotorBicycling.com
