Old 01-02-2010, 02:33 PM
Ron-P Ron-P is offline
Default WTB: 80cc Engine Block
Seems I might be on the market for an 80cc 2-stroke engine block. I had a mounting bolt break off inside the engine block and all attempts to get it out have failed. It's headed to a friends, if he cannot get it out I'll need a new block. Anyone have just the block, I don't need the carb, muffler and so on and I really don't want to have to spend $150+ on an entire new kit.
Old 01-02-2010, 08:45 PM
Nashville Kat's Avatar
Default Re: WTB: 80cc Engine Block
Boygofast has about the lowest retail on motor only-
80cc for $57 or best offer, and $13.50 shipping
Motorized BIKE GAS ENGINE parts - 80cc motor silver EPA - eBay (item 190356940420 end time Jan-08-10 19:36:49 PST)
Have you tried an "easy out" on the bolt? You drill into the screw and its like a corkscrew that pulls out the bolt. Don't know where to get one- but used them long, long ago.
http://thehearpe.com
Old 01-03-2010, 09:50 AM
flybytaco's Avatar
flybytaco flybytaco is offline
Metal Molding Madman
pm sent Ron
turnin n burnin @ PIRATE CYCLES
DUCATISTA
Old 01-03-2010, 08:54 PM
Thank you guys, and thanks for the link Kat, that's a great price. I put an offer in for $45. My friend got the bolt out but the first 3/16 of the block is chewed up a bit so a new block while not needed will make me feel more comfortable. Just not wanting to spend close to $100 if I can avoid it otherwise I'll just dump the cash and get an entirely new kit.
Old 01-03-2010, 08:59 PM
spit_fire's Avatar
spit_fire spit_fire is offline
i had the same issue, the block got so mangled that i cut out a little square out of it (were the whole stud was) and bolted a aluminium block rougly the same size back on there and covered it in jb weld including the stud let it sit for 3 dayz and it worked like a charm i even wiped out on the bike hard and it was still fine id suggest gupin the **** out of the stud with jb weld before puting it in of course this means that you wont be able to remove the stud
